Click the Exhibit button. You are configuring an interprovider Option C Layer 3 VPN to connect two customer sites. Referring to the exhibit, which three statements are correct? (Choose three.)
ASBR routers maintain the internal routes from its own AS, the loopback address from the other AS PEs, and the L3VPN routes.
ASBR routers maintain the internal routes from its own AS and the loopback addresses from the other AS PEs.
P routers maintain the internal routes from its own AS and the loopback address from the other AS PEs.
P routers only maintain the internal routes from their own AS.
PE routers maintain the internal routes from its own AS, the loopback address from the other AS Pes, and the L3VPN routes.
bde
uax
1 month ago
b) d) e) are correct
Want to join our community?
