You are responding to an RFP for a new MPLS VPN implementation. The solution must use LDP for signaling and support Layer 2 connectivity without using BGP. The solution must be scalable and support multiple VPN connections over a single MPLS LSP. The customer wants to maintain all routing for their private network.
In this scenario, which solution do you propose?
c) is correct
