You are configuring a BGP signaled Layer 2 VPN across your MPLS enabled core network. Your PE-2 device connects to two sites within the same VPN. In this scenario, which statement is correct?
You must create a unique Layer 2 VPN routing instance for each site on the PE-2 device.
By default on PE-2, the sites local ID is automatically assigned a value of 0 and must be configured to match the total number of attached sites.
You must use separate physical interfaces to connect PE-2 to each site.
By default on PE-2, the remote site IDs are automatically assigned based on the order that you add the interfaces to the site configuration.
uax
1 month ago
d) is correct
Want to join our community?
d) is correct
