jn0-664 question 66 discussion
back to juniper forum
Question 66
Referring to the exhibit, you must provide Internet access for VPN-A using CE-1 as the hub CE.
Which two statements are correct in this situation? (Choose two.)
  • A. Internet traffic from Site 2 takes the path of PE-2 -> PE-1 -> GW-1.
  • B. Internet traffic from Site 2 takes the path of PE-2 -> PE-1 -> CE-1 -> PE-1 -> GW-1.
  • C. You must use RIB groups to leak routes between the inet.0 and VPN-A.inet.0 tables.
  • D. RIB groups are not needed to leak routes between the inet.0 and VPN-A.inet.0 tables.
bc
uax
b) and c) if interface btw CE-1 and PE-1 is unique
uax
3 weeks, 5 days ago
otherwise b) and d) if there are 2 IFs btw CE1 and PE1, one in VRF, other in inet.0
