jn0-664 question 29 discussion
back to juniper forum
Question 29
You are attempting to summarize routes from the 203.0.113.128/25 IP block on R8 to AS 64500. You implement the export policy shown in the exhibit and all routes from the routing table stop being advertised.
In this scenario, which two steps would you take to summarize the route in BGP? (Choose two.)
  • A. Replace exact in the export policy with orlonger.
  • B. Remove the from protocol bgp command from the export policy.
  • C. Add the set protocols bgp family inet unicast add-path command to allow additional routes to the RIB tables.
  • D. Add the set routing-options aggregate route 203.0.113.128/25 command.
ad
uax
b) and d)
