jn0-664 question 27 discussion
back to juniper forum
Question 27
CE-1 and CE-2 are part of a VPLS called Customer1. No connectivity exists between CE-1 and CE-2. In the process of troubleshooting, you notice PE-1 is not learning any routes for this VPLS from PE-2, and PE-2 is not learning any routes for this VPLS from PE-1.
  • A. The route target must match on PE-1 and PE-2.
  • B. The instance type should be changed to l2vpn.
  • C. The no-tunnel-services statement should be deleted on both PEs.
  • D. The route distinguisher must match on PE-1 and PE-2.
uax
a) is correct
