jn0-664 question 22 discussion
back to juniper forum
Question 22
You are using a Layer 3 VPN to connect two customer sites. The VPN routes for the customer networks appear as hidden in the bgp.l3vpn.0 routing table on the PE routers.
What is causing this problem?
  • A. The routes use overlapping IP addresses.
  • B. There is a routing loop in the service provider backbone.
  • C. There is not an established MPLS LSP between the two PE routers.
  • D. Route targets are not configured.
uax
c) is correct
