jn0-664 question 125 discussion
back to juniper forum
Question 125
Referring to the exhibit, you must provide VRF Internet access over a single connection for VPN-A Site 1, which connects to PE-1.
Which two statements are correct in this scenario? (Choose two.)
  • A. You must use the RIB group to move interface routes from the inet.0 table to the VPN-A.inet.0 table.
  • B. You must use the RIB group to move a default route, which is learned through BGP, from the inet.0 table to the VPN-A.inet.0 table.
  • C. You do not need to use the RIB group to move interface routes from the inet.0 table to the VPN-A.inet.0 table.
  • D. You do not need to use the RIB group default route, which is learned through BGP, from the inet.0 table to the VPN-A.inet.0 table.
bc
uax
b) and c)
