You want to use both links between R1 and R2. Because of the bandwidth difference between the two links, you must ensure that the links are used as much as possible.
Which action will accomplish this goal?
Define a policy to tag routes with the appropriate bandwidth community
b) multipath and per-prefix LB are needed as well
