Click the Exhibit button. You are asked to exchange routes between R1 and R4 as shown in the exhibit. These two routers use the same AS number. Which two steps will accomplish this task? (Choose two.)
Configure the BGP group with the advertise-peer-as parameter on R2 and R3.
Configure the BGP group with the as-override parameter on R1 and R4.
Configure the BGP group with the advertise-peer-as parameter on R1 and R4.
Configure the BGP group with the as-override parameter on R2 and R3.
bd
hmvinueza
2 months ago
Correct is A y D
uax
1 month ago
d) for sure, a) ok
uax
4 weeks, 1 day ago
c) and d) better: advertise-peer-as is set on R1 and R4
uax
3 weeks, 2 days ago
a) and d) finally: both on R2/R3
Want to join our community?
Correct is A y D
d) for sure, a) ok
