jn0-664 question 106 discussion
back to juniper forum
Question 106
Your organization manages a Layer 3 VPN for multiple customers. To support advanced route filtering on your PE routers, you must advertise more than one BGP community on advertised VPN routes to remote PE routers.
Which routing-instance configuration parameter would support this requirement?
  • A. vrf-target import
  • B. vrf-export
  • C. vrf-target export
  • D. vrf-import
uax
b) is correct (can advertise more than one route target)
