SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Sales
You are using multiple address handling in a sales document. At which levels can you assign the address determination? Note: There are 2 correct answers to this question.
Address usage of the business partner
Origin and source of the partner function
Generic partner function
Partner determination procedure
A D
When a user creates a sales order with reference to a quotation, a header text must be automatically copied from the sold-to party if it cannot be found in quotation. If it is copied from the sold-to party, it must be in the sold-to party language. What must you do? Note: There are 3 correct answers to this question.
Assign an appropriate text type to the sales document type.
Include the text type with an appropriate access sequence in the text determination procedure.
Ensure that the access sequence reads the sold-to party text first.
In the access sequence, set the partner function language for this text to "sold-to party".
Assign the text determination procedure to the sales document type.
B D E
To which elements do you assign a partner determination procedure? Note: There are 3 correct answers to this question.
Delivery item category
Business partner category
Sales item category
Account group
Delivery type
C D E
Which of the following is a characteristic of decision table processing as used in SAP S/4HANA output management?
Every table row is processed in sequence. In each row, every condition column cell is processed from right to left.
It is possible to maintain one condition column cell with multiple result column cells for each table row.
Every condition column is processed in sequence. In each condition column, every row is processed from top to bottom.
It is possible to evaluate the content of condition column cells by using comparison operators or value ranges.
Which channels are supported by SAP S/4HANA output management? Note: There are 3 correct answers to this question.
ALE
Fax
E-mail
XML
Print
C D E
Texts are copied from a sold-to party to a sales order. Any later change to the sold-to party texts should not be visible in this order. Which object controls this behavior?
Text determination procedure
Access sequence
Text procedure assignment
Text ID
Which of the following settings are required to be able to deliver a product? Note: There are 2 correct answers to this question.
You need to set the Schedule Lines Allowed indicator in the item category.
You need to set up the item category as relevant for delivery-related billing.
You need to set up copying control in Logistics Execution System for the item category.
You need to set the Item Relevant for Delivery indicator in the item category.
A B
Which controls can you set when you configure a schedule line category? Note: There are 2 correct answers to this question.
Create delivery group
Delivery relevance
Structure scope
Goods movement type
B D
You sell a product for which there is a bill of material. What must you set to ensure that the components automatically appear as sub-items in the order?
The item usage during the item category determination of each sub-item
The delivery group in the item category of the sub-item
The material entry type in the sales document type
The structure scope in the item category of the main item
A reason for rejection has been set against a sales order item. Why is the net value of the item still included in the total net value of the order?
The reason for rejection was not assigned to the item category.
The reason for rejection does not have the appropriate configuration to exclude item value.
The item value is used statistically hence added to the net value.
The update of the net value is not triggered after the rejection of the item.
You want to determine the item category in a sales document. What do you need to consider? Note: There are 2 correct answers to this question.
The customer master data
The sales organization
The higher-level item
The material master data
C D
How do you restrict the reasons for rejection for a sales document?
Assign the permitted reasons for rejection to the relevant sales document type.
Assign the permitted reasons for rejection to the relevant sales item category.
Specify the permitted reasons for rejection in the relevant customer master.
Specify the permitted reasons for rejection in the customer material info record.
When you create a sales order with reference to a quotation, you want to ensure the entire quotation is always included in the order. Where do you make this setting?
Copying control
Order type
Order item category
Quotation type
You normally include multiple sales orders in your outbound deliveries. Which sales order fields would prevent this from happening if their content was different? Note: There are 3 correct answers to this question.
Route
Plant
Material group
Shipping point
Ship-to party
A D E
What settings should you make to ensure precise scheduling is used when the system performs delivery scheduling? Note: There are 3 correct answers to this question.
Maintain the transit time in the route in hours and minutes.
Assign a shift sequence to the working times.
Assign a set of working times to the plant.
Assign a set of working times to the shipping point.
Maintain shifts defining the times for starting and ending work.
