SAP Certified Associate - Implementation Consultant - SAP Ariba Sourcing
Which requirements must be met before you can use custom offline bidding? Note: There are 3 correct answers to this question.
Notifications will need to be enabled.
The event must have bidding rules enabled for offline responses.
Content items must be set for offline responses.
The template must be published and set to allow offline responses.
Alternative responses must be enabled.
B, C, D
Which of the following Customization Manager activities can be performed by the Customization Administrator system group? Note: There are 2 correct answers to this question.
Update bidder agreement text
Update site-wide company logo
Update enumerations
Access field configuration
What differences can you view with the BOM comparison feature? Note: There are 2 correct answers to this question.
Designed BOM and finished BOM
BOMs imported from the ERP and those created via CSV import
Different versions of the same BOM
Two distinct BOMs
Which of the following considerations should you keep in mind when using auction templates? Note: There are 2 correct answers to this question.
Runs over a short period of time
Price is the most important factor
Contains high price variance
Expected low competition between strategic and preferred suppliers
Which of the following factors would influence the success of an auction? Note: There are 2 correct answers to this question.
Participants are bidding in multiple currencies.
The supply base is competitive.
There are wide variations in product standards.
Raw material prices for the suppliers are rising.
Which of the following scoring rules must be set to enable blind team grading? Note: There are 2 correct answers to this question.
Default grading method
Allow participants to see scoring weights
Enable scoring on participant responses
Enable blind grading on participant responses
Which of the following fields contains a list of values that can act as a mini database where the selected value becomes a hyperlink that can open a window displaying additional data fields?
Flex Master Data
Integer
URL Link
Text Multiple Select
Which of the following sourcing event types should be used to collect each component of the price of a good or service?
Price breakdown
Bid transformation
Total cost
Index-based event
What limitations do large capacity events have outside of the user interface? Note: There are 2 correct answers to this question.
The system limit is 125 suppliers.
The system limit is 30 terms per line.
The system limits the bidding through Microsoft Excel only.
The system limit is 2000 line items.
Which of the following user groups are needed to use product sourcing functionality? Note: There are 2 correct answers to this question.
Materials User
BOM Administrator
Materials Manager
Materials Viewer
What does the BOM buy view allow you to do?
View the BOM hierarchy from the quote level and up.
Edit the BOM and add new materials.
Add the entire BOM to cart and purchase the parts.
See which materials will be ordered from suppliers.
Which bidding format is intended to be used when pricing terms are not equal across suppliers?
Price breakdown
Total cost
Bid transformation
Index-based
Which of the following event templates should be used when sourcing a commodity product that is subject to frequent price fluctuations, and where participants bid in discounts relative to a baseline?
Index-based auction
Total cost auction
Reverse auction with bid transformation
Traffic light auction
Which factors determine how rules are displayed in event templates? Note: There are 3 correct answers to this question.
Rules that are preset/hidden in a template
Event type
Conditional values from other rules
Currency rules
Conditional Sourcing Library content
What are the available event types when creating a quick project? Note: There are 3 correct answers to this question.
