python institute pcap-31-03 practice test
Certified Associate in Python Programming
Page 1 out of 10. Viewing questions 1-15 out of 147
What is true about Python packages? (Select two answers)
  • A. the__name__variable content determines the way in which the module was run
  • B. a package can be stored as a tree of sub-directories/sub-folders
  • C. __pycache__is the name of a built-in variable
  • D. hashbang is the name of a built-in Python function
A Python module named pymod.py contains a variable named pyvar.
Which of the following snippets will let you access the variable? (Select two answers)
  • A. import pyvar from pymod pyvar = 1
  • B. from pymod import pyvar = 1
  • C. from pymod import pyvar pyvar ()
  • D. import pymod pymod.pyvar = 1
AD
Assuming that the code below has been executed successfully, which of the following expressions
will always evaluate to True? (Select two answers)
import random
v1 = random. random()
v2 = random. random()
  • A. len(random.sample([1,2,3],2)) > 2
  • B. v1 == v2
  • C. random.choice([1,2,3]) >=1
  • D. v1 >= 1
With regards to the directory structure below, select the proper forms of the directives in order to
import module_
a. (Select two answers)
  • A. import pypack.module_a
  • B. import module_a from pypack
  • C. import module_a
  • D. from pypack import module_a
AD
Which one of the platform module functions should be used to determine the underlying platform
name?
  • A. platform.uname ()
  • B. platform.platform ()
  • C. platform.python_version()
  • D. platform.processor()
What is the expected output of the following code?
  • B. 0
  • C. False
  • D. None
What is true about the following snippet? (Select two answers)
  • A. the code will raise an unhandled exception
  • B. the string I feel fine 'will be seen
  • C. the string it's nice to see you will be seen
  • D. the string what a pity will be seen
What is the expected behavior of the following code?
  • A. it outputs 2
  • B. the code is erroneous and it will not execute
  • C. it outputs 1
  • D. it outputs 3
Which of the following snippets will execute without raising any unhandled exceptions? (Select
answers)
BCD
  • A. it outputs 1
  • B. it outputs 2
  • C. the code is erroneous and it will not execute
  • D. it outputs 3
  • A. it outputs error
  • B. it outputs list assignment index out of range
  • D. it outputs <class ' IndexError’ >
Which of the following expression evaluate to True? (Select two answers)
  • A. len('\'•) == 1
  • B. len(""" """) == o
  • C. chr(ordCA') + 1) == 'B'
  • D. ord("Z") - ord("z") -- ord("0")
  • A. it raises an exception
  • B. it outputs True
  • C. it outputs False
  • D. it outputs nothing
Which of the following expressions evaluate to True? (Select two answers)
  • A. 121 + 1 != '!' + 2 * '2'
  • B. 'AbC' lower () < 'AB'
  • C. '1' + '1' + '1' < '1' * 3'
  • D. '3.14' != str(3.1415)
  • A. str(1-1) in '012345£739'[:2]
  • B. 'phd' in 'alpha'
  • C. 'deb' not in 'abcde' [::-1]
  • D. 'True' not in 'False'
