A Service Order Orchestrator determines the steps required to complete the service. As an example, based on the state of the service point, what does the Enable Service Orchestrator determine the actions for?
A. Create a Device Configuration; Install a Device; Turn on the Device
B. Connect the Service Point; Install a Device; Create a Usage Subscription
C. Create a Service Point; Install a Device; Turn on the Device
D. Connect the Service Point; Install a Device; Turn on the Device
Which option correctly describes the high-level process from loading measurements through calculating usage?
A. 1. Load Initial Measurements 2. Validate, edit, and estimate Initial Measurements 3. Create Final Measurements 4. Update Initial Measurements
B. 1. Load Initial Measurements 2. Verify, evaluate, and enter Initial Measurements 3. Create Final Measurements 4. Calculate Usage
C. 1. Load Initial Measurements 2. Validate, evaluate, and estimate Initial Measurements 3. Update Initial Measurements 4. Calculate Usage
D. 1. Load Initial Measurements 2. Validate, edit, and estimate Initial Measurements 3. Create Final Measurements 4. Calculate Usage
How many bill segment-related financial transactions do Payment Arrangements have?
A. depends on the number of bills that will contain the customer’s payment arrangement details
B. one
C. depends on the number of payments that are part of the payment arrangement
Your implementation requires an installation of two types of devices: Electric Smart Meter Gas Manual Meter Which two Device Type attributes are required to identify these device types? (Choose two.)
A. Device Business Object
B. Service Type
C. Valid Measuring Component Types
D. Manufacturer
E. Serial Number
A device has one or more measuring components that measure consumption, demand, or other values. Which lists two attributes of a measuring component?
Your customers initial measurement data (IMD) has been imported and can be viewed through the Measuring Component portal, but is not in the Final measurement status. What can you assume that the IMD has passed?
A. Critical Validation
B. Multiplier Check Validation
C. Sum Check Validation
D. Critical Validation, High/Low Check Validation, and Sum Check Validation
E. High/Low Check Validation
Your client has three requirements: 1. Apply validations on meter reads coming from the Data Collectors. 2. If a meter read does not pass the validation, an error will be generated and assigned to a user. 3. Retry the validation every 30 minutes for the errors in case the issue is related to configuration. Which statement describes the base functions you should use?
A. If a To Do entry is created on the VEE exception, the IMDs Next Retry Date/Time is set to 30 minutes, and then processed by the algorithm D1-COMP-TD (Complete To Do Entries).
B. If a To Do entry is created on the VEE exception, the IMDs Next Retry Date/Time is set to 30 minutes, and then processed by the algorithm D1-IMD-RETRY (Retry Initial Measurement Data Processing)
C. If a To Do entry is created on the VEE exception, the user will need to discard the IMD and a new IMD will be loaded after 30 minutes.
D. If a To Do entry is created on the VEE exception, the IMDs Next Retry Date/Time is set to 30 minutes, and then processed by the algorithm D1-CRE-IMDTD (Create To Do)
E. If a To Do entry is created on the VEE exception, the user will need to discard the IMD and a new IMD will be manually loaded.
Which three are important Account concepts that must always be followed? (Choose three.)
A. Accounts expire when there are no active contracts.
B. An Account can only reference one and only one person at one time.
C. Every Account has a unique, system-assigned Account ID.
D. Bills are produced for an account and are sent to the account persons.
E. An Account references one or more persons.
BCD
Which three initial measurement data (IMD) exception categories are available when you execute VEE rules? (Choose three.)
When creating a new business object for a service point (SP), what items are required to be able to view and update the new elements associated with the SP?
A. Maintenance Object, Application Service, and Schema
B. Schema, Validation Algorithm, and Maintenance UI Map
C. Display UI Map, Display Map Service Script, and Maintenance UI Map
D. Validation Algorithm, Post Processing Algorithm, and Lifecycle
