oracle 1z0-909 practice test
MySQL 8.0 Database Developer
Examine these statements:
SET collation_connection=utf8mb4_0900_as_cs;
SELECT STRCMPCAlice', UCASE ('Alice* )) ;
What is displayed?
  • A. 0
  • B. ERROR: 1267 (HYOOO): Illegal mix of collations
  • C. -1
  • D. NULL
  • E. 1
Examine these commands and output:
Which is true?
  • A. Existing emp_vuL is dropped and a new emp_vu1 created with the new definition.
  • B. A new view is created because the previous was dropped on execution of the drop table statement.
  • C. It returns an error because the CREATE TABLE statement automatically recreated the view.
  • D. It returns an error because the DROP TABLE statement did not drop the view.
Which select statement returns true?
  • A. SELECT NULL <> NULL;
  • B. SELECT NULL <=> NULL;
  • C. SELECT NULL = NULL;
  • D. SELECT NULL := NULL;
Examine the structure of the emp table:
Examine the structure of the emp_vu1 view based on the emp table:
Now, examine this statement:
mysq1> INSERT INTO emp_vul VALUES ('Alice',20000) ;
What is true about executing the statement?
  • A. It inserts a row in the emp table.
  • B. It returns an error because an insert operation is not allowed on views.
  • C. It inserts a row in the view only.
  • D. It returns an error because the PRIMARY ACCOUNT column is not selected for the view definition.
Examine this statement which has executed successfully:
  • A. Execution performance can be improved by using like instead of RLIKE.
  • B. The statement takes advantage of index description_idx.
  • C. Execution performance can be improved by, using a composite index with column description as the leftmost prefix column description.
  • D. No index will improve statement performance.
  • E. Execution performance can be improved by adding an index on column description.
Which two differences exist between the timestamp and date time data types?
  • A. timestamp has larger range of values.
  • B. timestamp uses less storage space.
  • C. timestamp stores more decimal points in seconds
  • D. timestamp converts the value based on the session time zone.
  • E. timestamp stores the interval between two dates.
Which two are true about MySQL Document Store?
  • A. It helps to store data items in a schema-less key-value store.
  • B. It can store documents greater than 4 GB.
  • C. It depends heavily on strictly typed data.
  • D. It allows one to bypass the SQL layer of the server.
  • E. There is no access to relational tables.
AD
Examine this statement and output:
Now, examine these desired output values:
Which statement updates the table data as require
  • A. UPDATE exam_result SET score=TRUNCATE
  • B. UPDATE examresult SET score=ROUND(CEIL(score
  • C. UPDATE exam_result SET score=CEIL(TRUNCATE(sco
  • D. UPDATE exam_result SET score=CEIL(ROUND(score,1));
  • E. UPDATE exam_result SET score=ROUND(score,1);
  • F. UPDATE exam_result SET score=TRUNCATE(score,1);
Examine this statement:
  • A. Inserting COMMIT; SET @m :=: before line 4
  • B. user who creates the procedure needing the create and execute privileges
  • C. user who creates the procedure needing the create routine privilege
  • D. inserting USE <database >; before line 3
  • E. Inserting DEFINER 'username '@' localhost' clause into the CREATE PROCEDURE statement
You must enforce data integrity for data Inserted in a JSON column.
Which statement successfully creates a constraint in a 3SON column?
  • A. CREATE TABLE fshop (product JSON CHECK (JSON_VALID(product) ) ) ;
  • B. CREATE TABLE fshop ( product JSON, f INT' GENERATED ALWAYS AS (product->"S - id") ) ;
  • C. CREATE TABLE fshop (id INT NOT NULL AUTOINCREMENT, product JSON, PRIMARY KEY (id)) ENGINE=InnoDB;
  • D. CREATE TABLE fshop (id INT NOT NULL AUTO_ INCREMENT, product JSON, CHECK (id>0) ) ENGXNE=InnoDB;
Examine these my.cnf settings:
Examine this entry from /data/slow.log
Which option is also set in my.cnf?
  • A. log_queries_not_using_indexes
  • B. log__slow_admin_statements=1
  • C. log_queries_not_using_indexes=ON
  • D. log_throttle_queries_not_using_indexes=100
Examine this bar graph based on columns from the players table:
Which two statements would generate this bar graph?
  • A. SELECT Name, Gender, Sport, REPEAT('# 'Y GPA*10) AS GPA_Graph FROM players ORDER BY GPA DESC;
  • B. SELECT Name, Gender, Sport, LENGTH (GPA*10, '# ') AS GPA_Graph FROM players ORDER BY GPA DESC;
  • C. SELECT Name, Gender, Sport, CHAR_LENGTH ('# ' GPA*10) AS GPA_Graph FROM players ORDER BY GPA DESC;
  • D. SELECT Name, Gender, Sport, RPAD ('# ' GPA*10) AS GPA_Graph FROM players ORDER BY GPA DESC;
  • E. SELECT Name, Gender, Sport, CONCAT ('# ' GPA*10) AS GPA_Graph FROM players ORDER BY GPA DESC;
AD
Examine these commands which execute successfully in the sequence shown in Sessions S1 and S2:
Now, examine this statement that execute successfully in s1:
S1> SELECT * FROM emp;
Which is true about the result of the select statement?
  • A. The inserted row is returned because the transaction is auto committed in S2.
  • B. The inserted row is not returned because the isolation level is READ COMMITTED in S2.
  • C. The inserted row is not returned because the transaction still active in s2.
  • D. The inserted row is returned because the isolation level is RPEATABLE READ in S1.
Which two statements are true about AUTO_INCREMENT?
  • A. AUTO_INCREMENT values allocated to a transaction that is rolled back are not reused.
  • B. A table can have multiple AUTO_INCREMENT columns.
  • C. A server restart always resets the AUTO_INCREMENT value to largest value in the AUTO_INCREMENT column plus 1.
  • D. The decimal data type supports AUTO_INCREMENT.
  • E. An AUTO_INCREMENT column must be indexed.
AE
Examine the contents of these tables:
Now examine the expected results for a user with privileges to access the table:
Which query returns the expected results?
