oracle 1z0-811 practice test
Java Foundations
Which statement is true about primitive variables?
  • A. They can be compared with the == operator.
  • B. They can be compared with the equals method only.
  • C. They cannot be compared.
  • D. They can be compared with the compareTo method only.
Reference: https://stackoverflow.com/questions/9690981/compare-two-primitive-long-variables-in-
java
Given the code fragment:
What is the result?
  • A. 2
  • B. 4
  • C. The program executes an infinite number of times.
  • D. 3
Identify two Java reserved words.
  • A. array
  • B. true
  • C. this
  • D. exception
  • E. string
Reference: https://www.computerhope.com/jargon/j/java_reserved_words.htm
Which statement is true about a Java method?
  • A. It must be declared with an access modifier.
  • B. It cannot be defined within another method.
  • C. It must accept a parameter and return a value.
  • D. It cannot be defined as static final.
Reference: https://www.quora.com/Can-we-define-a-function-within-another-function-in-Java
Given:
And the code fragment:
Which code fragment can be inserted at line n1 to enable the code to print All the best?
  • A. void writeMsg();
  • B. Messenger.writeMsg();
  • C. writeMsg();
  • D. m.writeMsg();
Which two code fragments are valid at line 2?
for (int count = 0; count < 5; count++) {
System.out.print(count);
package p1;
import java.util.*;
public void display() {
List<Integer> nums = new ArrayList<> ();
private int num;
private String name = “John”;
System.out.print(name);
B, E
You have been asked to develop a Java program that prints the elements of an array in reverse order.
Which looping statement cannot be used to meet the requirement?
  • A. enhanced for
  • B. standard for
  • C. while
  • D. do-while
Reference: https://www.javatpoint.com/java-program-to-print-the-elements-of-an-array-in-reverse-
order
Which statement is true?
The code results in a compilation error. To make it compile, insert at line n1:
import java.lang.Math;
import java.lang.Random;
The code compiles successfully
import java.lang;
import java.util;
import java.util.*;
What is the result?
  • A. pen pencil erasers paper
  • B. paper pen pencil erasers
  • C. A compilation error occurs.
  • D. A runtime exception is thrown.
Which code fragment, when inserted at line n1, enables the code to print Java Programming:1?
  • A. System.out.println(name + “:” + count);
  • B. System.out.println(c.name + “:” + count);
  • C. System.out.println(c.name + “:” + Course.count);
  • D. System.out.println(Course.name + “:” + c.count);
Given:
What is the result?
  • A. [null:-]
  • B. [ : ]
  • C. [null:null]
  • D. [:null]
Which two Java reserved words are used to implement encapsulation?
  • A. final
  • B. static
  • C. public
  • D. extends
  • E. private
C, E
Reference: https://learn.saylor.org/mod/page/view.php?id=22044
Which code fragment can be inserted at line n1 to enable the code to print 0.0?
Ball b = null;
b.weight = 0.0;
Ball.weight = 0.0;
Ball b = new Ball(0.0);
Ball b = new Ball();
Which two statements are true about the Java Runtime Environment (JRE)?
  • A. It is responsible for garbage collection.
  • B. It interprets bytecode stored in a .class file.
  • C. It contains the JDK and Java APIs.
  • D. It is platform independent.
  • E. You must install the JRE to compile a .java file.
Reference: https://en.wikipedia.org/wiki/Java_virtual_machine
Identify two features of Java.
  • A. architecture dependent
  • B. platform independent
  • C. single threaded
  • D. robust
Reference: https://www.javatpoint.com/features-of-java
