Identify the two benefits of using Multi-Org Access Control. (Choose two.)
D,E
Identify two options that users can specify using Multi-Org preferences. (Choose two.)
A,E
View the Exhibit.
While entering a journal in the Journals form, you enter a code combination of
29.402.4519.2103.240 in the five-segment Accounting Flex field. However, you are unable to proceed
after entering this account combination. What could be the problem in the structure definition of the
Accounting Flex field?
XYZ Corp. has acquired ABC Corp. XYZ operates with Multi-Org Access Control. Consequently XYZ
Corp. needs to add additional Operating Units. Identify the statement that describes the sequence
for adding additional Operating Units.
A Global Single Instance (GSI) provides global enterprise with a single, complete data model, Identify
three features in Oracle E-Business Suite Release 12 that support a GSI, (Choose three)
B,D,E
Which two statements are true regarding ownership of shared entities? (Choose two)
B,C
Identify two Descriptive Flex field components whose values are used to determine Contexts.
A,C
Identify two features of a Value Set that has a validation type of "None." (Choose two.)
B,C
Identify the four resources that Oracle Technology Network (OTN) provides. (Choose four.)
A,C,D,E
Which four products In Oracle E-Business Suite Release 12 require a Multi-Org setup? (Choose four)
A,B,C,E
