oracle 1z0-1122-25 practice test
Oracle Cloud Infrastructure 2025 AI Foundations Associate
Page 1 out of 3. Viewing questions 1-15 out of 41
What is the key feature of Recurrent Neural Networks (RNNs)?
  • A. They process data in parallel.
  • B. They are primarily used for image recognition tasks.
  • C. They have a feedback loop that allows information to persist across different time steps.
  • D. They do not have an internal state.
Recurrent Neural Networks (RNNs) are a class of neural networks where connections between nodes
can form cycles. This cycle creates a feedback loop that allows the network to maintain an internal
state or memory, which persists across different time steps. This is the key feature of RNNs that
distinguishes them from other neural networks, such as feedforward neural networks that process
inputs in one direction only and do not have internal states.
RNNs are particularly useful for tasks where context or sequential information is important, such as
in language modeling, time-series prediction, and speech recognition. The ability to retain
information from previous inputs enables RNNs to make more informed predictions based on the
entire sequence of data, not just the current input.
In contrast:
Option A (They process data in parallel) is incorrect because RNNs typically process data sequentially,
not in parallel.
Option B (They are primarily used for image recognition tasks) is incorrect because image recognition
is more commonly associated with Convolutional Neural Networks (CNNs), not RNNs.
Option D (They do not have an internal state) is incorrect because having an internal state is a
defining characteristic of RNNs.
This feedback loop is fundamental to the operation of RNNs and allows them to handle sequences of
data effectively by "remembering" past inputs to influence future outputs. This memory capability is
what makes RNNs powerful for applications that involve sequential or time-dependent data​​​​​.
What role do Transformers perform in Large Language Models (LLMs)?
  • A. Limit the ability of LLMs to handle large datasets by imposing strict memory constraints
  • B. Manually engineer features in the data before training the model
  • C. Provide a mechanism to process sequential data in parallel and capture long-range dependencies
  • D. Image recognition tasks in LLMs
Transformers play a critical role in Large Language Models (LLMs), like GPT-4, by providing an
efficient and effective mechanism to process sequential data in parallel while capturing long-range
dependencies. This capability is essential for understanding and generating coherent and
contextually appropriate text over extended sequences of input.
Sequential Data Processing in Parallel:
Traditional models, like Recurrent Neural Networks (RNNs), process sequences of data one step at a
time, which can be slow and difficult to scale. In contrast, Transformers allow for the parallel
processing of sequences, significantly speeding up the computation and making it feasible to train on
large datasets.
This parallelism is achieved through the self-attention mechanism, which enables the model to
consider all parts of the input data simultaneously, rather than sequentially. Each token (word,
punctuation, etc.) in the sequence is compared with every other token, allowing the model to weigh
the importance of each part of the input relative to every other part.
Capturing Long-Range Dependencies:
Transformers excel at capturing long-range dependencies within data, which is crucial for
understanding context in natural language processing tasks. For example, in a long sentence or
paragraph, the meaning of a word can depend on other words that are far apart in the sequence. The
self-attention mechanism in Transformers allows the model to capture these dependencies
effectively by focusing on relevant parts of the text regardless of their position in the sequence.
This ability to capture long-range dependencies enhances the model's understanding of context,
leading to more coherent and accurate text generation.
Applications in LLMs:
In the context of GPT-4 and similar models, the Transformer architecture allows these models to
generate text that is not only contextually appropriate but also maintains coherence across long
passages, which is a significant improvement over earlier models. This is why the Transformer is the
foundational architecture behind the success of GPT models.
Transformers are a foundational architecture in LLMs, particularly because they enable parallel
processing and capture long-range dependencies, which are essential for effective language
understanding and generation​​​​.
Which is NOT a category of pretrained foundational models available in the OCI Generative AI
service?
  • A. Embedding models
  • B. Translation models
  • C. Chat models
  • D. Generation models
The OCI Generative AI service offers various categories of pretrained foundational models, including
Embedding models, Chat models, and Generation models. These models are designed to perform a
wide range of tasks, such as generating text, answering questions, and providing contextual
embeddings. However, Translation models, which are typically used for converting text from one
language to another, are not a category available in the OCI Generative AI service's current offerings.
The focus of the OCI Generative AI service is more aligned with tasks related to text generation, chat
interactions, and embedding generation rather than direct language translation​.
What does "fine-tuning" refer to in the context of OCI Generative AI service?
  • A. Encrypting the data for security reasons
  • B. Adjusting the model parameters to improve accuracy
  • C. Upgrading the hardware of the AI clusters
  • D. Doubling the neural network layers
Fine-tuning in the context of the OCI Generative AI service refers to the process of adjusting the
parameters of a pretrained model to better fit a specific task or dataset. This process involves further
training the model on a smaller, task-specific dataset, allowing the model to refine its understanding
and improve its performance on that specific task. Fine-tuning is essential for customizing the
general capabilities of a pretrained model to meet the particular needs of a given application,
resulting in more accurate and relevant outputs. It is distinct from other processes like encrypting
data, upgrading hardware, or simply increasing the complexity of the model architecture​​.
What is the primary benefit of using Oracle Cloud Infrastructure Supercluster for AI workloads?
  • A. It delivers exceptional performance and scalability for complex AI tasks.
  • B. It is ideal for tasks such as text-to-speech conversion.
  • C. It offers seamless integration with social media platforms.
  • D. It provides a cost-effective solution for simple AI tasks.
Oracle Cloud Infrastructure Supercluster is designed to deliver exceptional performance and
scalability for complex AI tasks. The primary benefit of this infrastructure is its ability to handle
demanding AI workloads, offering high-performance computing (HPC) capabilities that are crucial for
training large-scale AI models and processing massive datasets. The architecture of the Supercluster
ensures low-latency networking, efficient resource allocation, and high-throughput processing,
making it ideal for AI tasks that require significant computational power, such as deep learning, data
analytics, and large-scale simulations​.
Which AI Ethics principle leads to the Responsible AI requirement of transparency?
  • A. Explicability
  • B. Prevention of harm
  • C. Respect for human autonomy
  • D. Fairness
Explicability is the AI Ethics principle that leads to the Responsible AI requirement of transparency.
This principle emphasizes the importance of making AI systems understandable and interpretable to
humans. Transparency is a key aspect of explicability, as it ensures that the decision-making
processes of AI systems are clear and comprehensible, allowing users to understand how and why a
particular decision or output was generated. This is critical for building trust in AI systems and
ensuring that they are used responsibly and ethically​​.
Top of Form
Bottom of Form
How is "Prompt Engineering" different from "Fine-tuning" in the context of Large Language Models
(LLMs)?
  • A. Prompt Engineering creates input prompts, while Fine-tuning retrains the model on specific data.
  • B. Both involve retraining the model, but Prompt Engineering does it more often.
  • C. Prompt Engineering adjusts the model's parameters, while Fine-tuning crafts input prompts.
  • D. Prompt Engineering modifies training data, while Fine-tuning alters the model's structure.
In the context of Large Language Models (LLMs), Prompt Engineering and Fine-tuning are two
distinct methods used to optimize the performance of AI models.
Prompt Engineering involves designing and structuring input prompts to guide the model in
generating specific, relevant, and high-quality responses. This technique does not alter the model's
internal parameters but instead leverages the existing capabilities of the model by crafting precise
and effective prompts. The focus here is on optimizing how you ask the model to perform tasks,
which can involve specifying the context, formatting the input, and iterating on the prompt to
improve outputs .
Fine-tuning, on the other hand, refers to the process of retraining a pretrained model on a smaller,
task-specific dataset. This adjustment allows the model to adapt its parameters to better suit the
specific needs of the task at hand, effectively "specializing" the model for particular applications.
Fine-tuning involves modifying the internal structure of the model to improve its accuracy and
performance on the targeted tasks .
Thus, the key difference is that Prompt Engineering focuses on how to use the model effectively
through input manipulation, while Fine-tuning involves altering the model itself to improve its
performance on specialized tasks.
Which type of machine learning is used to understand relationships within data and is not focused on
making predictions or classifications?
  • A. Reinforcement learning
  • B. Unsupervised learning
  • C. Active learning
  • D. Supervised learning
Unsupervised learning is a type of machine learning that focuses on understanding relationships
within data without the need for labeled outcomes. Unlike supervised learning, which requires
labeled data to train models to make predictions or classifications, unsupervised learning works with
unlabeled data and aims to discover hidden patterns, groupings, or structures within the data.
Common applications of unsupervised learning include clustering, where the algorithm groups data
points into clusters based on similarities, and association, where it identifies relationships between
variables in the dataset. Since unsupervised learning does not predict outcomes but rather uncovers
inherent structures, it is ideal for exploratory data analysis and discovering previously unknown
patterns in data .
What is the benefit of using embedding models in OCI Generative AI service?
  • A. They optimize the use of computational resources.
  • B. They simplify managing databases.
  • C. They facilitate semantic searches.
  • D. They enable creating detailed graphics.
Embedding models in the OCI Generative AI service are designed to represent text, phrases, or other
data types in a dense vector space, where semantically similar items are located closer to each other.
This representation enables more effective semantic searches, where the goal is to retrieve
information based on the meaning and context of the query, rather than just exact keyword matches.
The benefit of using embedding models is that they allow for more nuanced and contextually
relevant searches. For example, if a user searches for "financial reports," an embedding model can
understand that "quarterly earnings" is semantically related, even if the exact phrase does not
appear in the document. This capability greatly enhances the accuracy and relevance of search
results, making it a powerful tool for handling large and diverse datasets .
You are working on a multilingual public announcement system. Which AI task will you use to
implement it?
  • A. Speech recognition
  • B. Text summarization
  • C. Audio recording
  • D. Text to speech
For a multilingual public announcement system, the AI task that would be most relevant is "Text to
Speech" (TTS). This task involves converting written text into spoken words, which can then be
broadcasted over public address systems in multiple languages.
Text to Speech technology is crucial for creating accessible and understandable announcements in
different languages, especially in environments like airports, train stations, or public events where
clear verbal communication is essential. The TTS system would be configured to support multiple
languages, allowing it to deliver announcements to diverse audiences effectively .
What is a key advantage of using dedicated AI clusters in the OCI Generative AI service?
  • A. They allow access to unlimited database resources.
  • B. They are free of charge for all users.
  • C. They provide high performance compute resources for fine-tuning tasks.
  • D. They provide faster internet connection speeds.
The primary advantage of using dedicated AI clusters in the Oracle Cloud Infrastructure (OCI)
Generative AI service is the provision of high-performance compute resources that are specifically
optimized for fine-tuning tasks. Fine-tuning is a critical step in the process of adapting pre-trained
models to specific tasks, and it requires significant computational power. Dedicated AI clusters in OCI
are designed to deliver the necessary performance and scalability to handle the intense workloads
associated with fine-tuning large language models (LLMs) and other AI models, ensuring faster
processing and more efficient training​​.
You are working on a project for a healthcare organization that wants to develop a system to predict
the severity of patients' illnesses upon admission to a hospital. The goal is to classify patients into
three categories – Low Risk, Moderate Risk, and High Risk – based on their medical history and vital
signs. Which type of supervised learning algorithm is required in this scenario?
  • A. Regression
  • B. Multi-Class Classification
  • C. Binary Classification
  • D. Clustering
In this healthcare scenario, where the goal is to classify patients into three categories—Low Risk,
Moderate Risk, and High Risk—based on their medical history and vital signs, a Multi-Class
Classification algorithm is required. Multi-class classification is a type of supervised learning
algorithm used when there are three or more classes or categories to predict. This method is well-
suited for situations where each instance needs to be classified into one of several categories, which
aligns with the requirement to categorize patients into different risk levels​​.
What is the purpose of Attention Mechanism in Transformer architecture?
  • A. Weigh the importance of different words within a sequence and understand the context.
  • B. Convert tokens into numerical forms (vectors) that the model can understand.
  • C. Break down a sentence into smaller pieces called tokens.
  • D. Apply a specific function to each word individually.
The purpose of the Attention Mechanism in Transformer architecture is to weigh the importance of
different words within a sequence and understand the context. In essence, the attention mechanism
allows the model to focus on specific parts of the input sequence when producing an output, which is
crucial for understanding context and maintaining coherence over long sequences. It does this by
assigning different weights to different words in the sequence, enabling the model to capture
relationships between words that are far apart and to emphasize relevant parts of the input when
generating predictions​​.
Top of Form
Bottom of Form
How does AI enhance human efforts?
  • A. By increasing the physical strength of humans
  • B. By deleting data humans need to handle
  • C. By completely replacing human workers in all tasks
  • D. By processing data at a speed and effectiveness far beyond human capability
AI enhances human efforts by processing large volumes of data quickly and accurately, performing
complex computations that would be time-consuming or impossible for humans to handle manually.
This allows humans to focus on more strategic, creative, and decision-making tasks, leveraging AI's
ability to provide insights, automate repetitive processes, and support decision-making. AI does not
physically enhance human capabilities, nor does it replace human workers in all tasks. Instead, it
serves as an augmentation tool, amplifying human productivity and capabilities​​.
Which algorithm is primarily used for adjusting the weights of connections between neurons during
the training of an Artificial Neural Network (ANN)?
  • A. Gradient Descent
  • B. Backpropagation
  • C. Random Forest
  • D. Support Vector Machine
Backpropagation is the algorithm primarily used for adjusting the weights of connections between
neurons during the training of an Artificial Neural Network (ANN). It is a supervised learning
algorithm that calculates the gradient of the loss function with respect to each weight by applying
the chain rule, propagating the error backward from the output layer to the input layer. This process
updates the weights to minimize the error, thus improving the model's accuracy over time.
Gradient Descent is closely related as it is the optimization algorithm used to adjust the weights
based on the gradients computed by backpropagation, but backpropagation is the specific method
used to calculate these gradients​​.
