What happens to a reconciliation if a team member who prepared the reconciliation is deleted from
the team at a later point of time?
Which three fields are required in a load file for pre-mapped balances?
ADF
Which statement is FALSE about calendars?
Which two are matching rule types?
An error occurs during an import transactions job for a match type. What is the result of the job?
Which statement is FALSE regarding user-defined attributes?
Which is true when you reopen a reconciliation?
Which two tasks can be performed using EPM Automate?
Which two statements are true about reconciliation compliance filters?
The objects within the match type refer to data sources, the data source attributes, the match
processes, the rules, and the rule conditions. Which statement is FALSE about importing a match
type with the same name as an existing match type?
