Examine the udevadm command:
udevadm info --attribute-walk --name =/dev/sdb
Which two statements are true about this command/
C D
Which two statements are true about a btrfs file system on a SSD flash disk? (Choose two.)
B D
Examine the output of the lscgroup command:
cpuset, cpu, memory:/ cpuset, cpu, memory:/A2 cpuset, cpu, memory:/A2/A3 cpuset, cpu, memory:/B1 cpuset, cpu,
memory:/A1 blkio:/ blkio:/B1 cpuacct:/
Which statement changes the shares parameter of the cpu subsystem for the group A3 to a value of 2?
Examine the configuration steps 1 through 5:
1 Discover iSCSI targets available to the client system.
2 Establish iSCSI sessions.
3 Start the iscsi initiator daemon.4 Create iSCSI interfaces.
Which option represents the correct order for iSCSI client configuration?
Which two statements are true about OCFS2 configuration? (Choose two.)
A B
Examine the output of the kpartx command:
The ./virtual_disk.ing file contaons an ext3 file system.
Which command would you use to mount this file system on/mnt?
A C
Which two statements are correct about features and capabilities of virtualization in Oracle Linux?
C D
Examine these commands and their output:
The next command you run is:
# xfs_growfs /xfs1
What is the result of running this command?
After creating empty mount point /xfs1, you execute the command:
# mkfs t xfs L /xfs1 l logdev=/dev/sdd1 /dev/sdh1
Which two statements are true about the effects of executing the mkfs command?
D F
Examine the output displayed on a DHCP server:
All addresses in RANGE have been leased and have not yet expired.
An additional client, other than HOST201, requests a lease on the 192.168.100.0 subnet from the DHCP server.
What is the outcome of the request for this lease?
