When defining the frequency or schedule orchestration style integration runs you can choose either
Basic or Advance option? Which expression language is used for defining advanced schedule runs?
Oracle Integration Cloud (OIC) provides the File Server component - an embedded SFTP server that
enables organizations to focus on building integrations without needing to host and maintain
separate SFTP server. Which statement is NOT true about the OIC File Server component?
When creating integration in Oracle Integration Cloud (OIC), a visual mapper enables your element
nodes between applications by dragging source element nodes onto target element nodes. Which
statement is NOT true about the OIC data mapper functionality?
Which two statements are true regarding mapper activity?
Which adapter is NOT provided in the Oracle Cloud adapter with Oracle SOA Cloud Service?
One of your downstream applications is becoming overwhelmed with too many individual
synchronous invocations from you current Oracle Integration Cloud (OIC) integration. It has been
recommended that you redesign the integration to take advantage of the catch processing
capabilities of the application. Which is the MOST appropriate approach for implementing this OIC
design best practice?
Which three statements are true about SOAP and the advantages it provides?
ADE
Which OIC XPATH function can be used to retrieve data from OIC Lookup within the data mapper
tool?
With regard to OIC Lookups, Which two are valid statements?
DE
OIC is available in two editions - Standard and Enterprise.
Which OIC Enterprise Edition capabilities are ALSO available in the OIC Standarf edition? (Select two)
EF
