How should you include the IDC report in a customer proposal?
The director of a big data organization appreciates the overall Nutanix value proposition but is
skeptical that it can perform in a large Splunk deployment.
Which case studies should you use to overcome the skepticism?
Consider the Arizona State University (ASU) story in which they reaped the benefits of a Nutanix
Enterprise Cloud Platform. Which primary pain point did deploying Nutanix help ASU overcome?
How does Veeam compliment Nutanix infrastructure, what are the most relevant capabilities?
How can I easily learn more about Nutanix Ready AHV validated solutions?
What is the key benefit of Nutanix InstantON for Citrix Cloud?
What is the primary concern of a typical system administrator?
Which action can you take to obtain a customized TCO/ROI report?
A customer adopts Nutanix for their VDI workload. In a follow-up discussion, it becomes apparent
that the customer has new-found user profile and home directory storage.
Which Nutanix product should be positioned to this custome?
A system administrator is updating 3-tier environment with 3 hardware vendors. Each update must
be compatible with the next. The system administrator is considering Nutanix as an alternative
architecture as a standard for future projects. Which advantage will the Nutanix solution provide to
help the system administrator in this situation?
