iSQI ctfl-act practice test
ISTQB Foundation Level - Acceptance Testing Exam
Which tool fits the mentioned acceptance test activities BEST?
  • A. Requirements management tools for managing acceptance test execution campaigns.
  • B. Test management and automation tools for business process model-based acceptance test generation.
  • C. Business process management tools for modeling business processes and rules.
  • D. Model-based testing tools for managing incidents.
Which one of the following sentences describes BEST a major advantage when business analysts and
testers review the acceptance criteria together?
  • A. A shared vision between the business analyst and the tester on acceptance criteria facilitates the design of acceptance test cases.
  • B. A joint review ensures that non-functional quality criteria are taken into account.
  • C. The review of acceptance criteria helps to verify that acceptance test cases cover business processes, business rules and business risks.
  • D. The review of acceptance criteria is a good practice to improve the quality of test reports.
Which of the following techniques is most likely applied to ensure the quality of acceptance testing
activities?
  • A. Review of the source code to ensure traceability of user stories to system components.
  • B. Verification of the traceability between user stories and test cases to make sure it is up to date.
  • C. Checklist-based verification of requirements to ensure their completeness and quality.
  • D. Eye tracking to verify the feasibility of previously defined user acceptance tests.
Which of the following information is most likely part of an acceptance test summary report?
  • A. Information to evaluate the level of risk for product release.
  • B. Technical details on defect fixes.
  • C. Test strategy and test design methods.
  • D. Test procedure information.
Which of the following activities is most likely performed by the business analyst as part of defect
analysis?
  • A. Identify the requirements / user stories that are not satisfied.
  • B. Assess the impact of corrective actions on other parts of the system's implementation.
  • C. Analyze the function that failed step by step to identify the cause of the defect.
  • D. Check, whether other paths in the business process model perform as intended.
Which of the following statements regarding defects is MOST correct?
  • A. Regular meetings between business analysts and testers are necessary to report discrepancies between actual and expected outcome.
  • B. Testers should provide accurate information regarding the difference between the expected test result and the actual result.
  • C. If the defect turns out to be a bug, the tester writes a defect report and sends it to the business analyst for further investigation.
  • D. The tester should analyze the potential impact of a defect on system usage, before communicating it to the business analyst.
You are leading a brand new project team whose members are coming from all over the organization
and have no former experience in working together. You need to build a common vision and team
spirit. What workshop would fit BEST:
  • A. You invite the team members and ask them to design their own (team-wise) emblem representing their values, beliefs, goals, tasks together than a common motto.
  • B. You invite every member in turn to describe his/her past experience and his/her major achievements in the organization or in their former job.
  • C. You ask every member in turn to write down three things he/she likes and dislikes in the organization and to post them on a wall. A volunteer is then chosen to read randomly some posts that are then discussed with the group.
  • D. You draw a staircase with 11 steps, each of them representing a major milestone of the project. The bottom of the stairs corresponds to the first day of the project and the upper step means that the project is released. You locate the present situation in the top of the stairs. The team is asked to identify and discuss the major steps downwards.
The project team is currently facing a difficult situation originating from their difficulty in envisioning
the future and the necessary steps to reach it together with a certain loss of motivation due to a
strong feeling of stagnation. You try to unlock the situation by proposing a workshop. Which one
would fit the best?
  • A. You ask two volunteers to play a part in front of the team. One will try to defend the project and propose positive arguments and ways forward. The other will do the opposite. You then recapitulate the major arguments of both sides and debate them openly with the team.
  • B. You draw a staircase with 11 steps, each of them representing a major milestone of the project. The bottom of the stairs corresponds to the first day of the project and the upper step means that the project is released. You locate the present situation in the middle of the stairs. The team is asked to identify and discuss the major steps down and up.
  • C. You organize a day out with challenging physical exercises practiced in teams followed by an afterwork dinner and drink. After all, nothing is best for motivation than hard times together, strong common objectives and a promise of good time.
  • D. You visualize all remaining major milestones of the project, starting with today and ending with project release. Then, you ask the team to identify and discuss the necessary actions to move forward from the present situation and to reach the milestones.
Which one of the following acceptance criteria relates to security requirements?
  • A. The system's response time shall not exceed 3 seconds.
  • B. The system shall be web-based.
  • C. The graphical user interface shall comply with corporate style guides.
  • D. Normal users shall have restricted access to private data.
Which one of the following combinations of given perspective and statement matches BEST?
  • A. From a business perspective, computing power and architecture are major parameters for fine- tuning the system.
  • B. From a user perspective, missing feedback from the system when processing a request it is a problem.
  • C. From a technical perspective, the number of concurrent user and the types of transactions performed are major elements.
  • D. From a business perspective, the choice of performance test tools strongly depends on the applied test techniques.
