Huawei firewall nat outbound which supports the following scenario? (Choose three)
A. One address translation
B. -Many address translation
C. -Many address translation
D. Many-to- address translation
A, C, D
109/109
Which of the following IKE exchange mode does not provide identity protection?
The main difference between symmetric and asymmetric encryption algorithm encryption algorithm
that different algorithms, but they are using the same key to encrypt and decrypt.
In the USG (Eudemon) series firewall, which of the following techniques first to be matched?
Establish a GRE tunnel between the two companies through the Internet Internet, the A corporate
network port IP address is 192.168.0.1, Tunnel port IP address is 10.10.10.1, Loopback port IP
address is 172.16.15.1, external network is 171.13.15.1. Will the Tunnel interface mode, source
address is configured which one?
All Categories Access Control List support for IP access control quintuple
Use NAT technology, the data packets in the network layer information (IP header) for encryption to
enhance the security of the data.
For the end user, SVN equivalent web___________, while the internal servers, SVN has assumed the
role of __________ of:
107/109
Questions & Answers PDF
P-
ADSL configure dialer-rule 1 ip permit, and configuration of the following correspondence between?
You can also use the template mode IPSEC remote-address is the address specified above.
