Huawei h35-920 practice test
HCIA-OWS Developer V1.0
Last exam update: Nov 09 ,2026
Page 1 out of 17. Viewing questions 1-15 out of 250
Regarding on Forms, there is no "data exist check" component in mobile page.
Which of the following statements are correct about app import and export? (Multiple Choice)
  • A. App export includes information such as model, pages, services, and rules.
  • B. App export and import enable apps to be migrated in different environments.
  • C. Model can be exported separately or exported with the App.
  • D. App export can contain model data. However, it is not recommended to export model data that contains a large amount of data.
ABCD
What are the pain points of traditional IT software architecture and development process? (Multiple
Choice)
  • A. The TTM of software development takes a long time.
  • B. Requirements may not be properly understood during the communication process.
  • C. Difficult to customize
  • D. No information sharing
ABCD
How many types of security policy of interface packages?
  • A. One type
  • B. Two types
  • C. Three types
  • D. Four types
Which of the following statements is correct about the release process of mobile app?
  • A. The apps that do not contain mobile pages can be used only after they are released to mobile phones.
  • B. After a mobile app is released, it can be updated on the mobile phone without being released again.
  • C. Mobile apps can be used on mobile phones without being released.
  • D. A released app can be synchronized to the mobile phone only after being upgraded and the version must be newer than the previous version.
Which of the following statements is correct about Date?
  • A. The property of the Date type can be used as the primary key.
  • B. The property of the Date type can be set with default value.
  • C. You can set the start time and end time for the property of the Date type.
The request method of the Outbound REST interface does not need to be configured according to the
third party requirements. The request can be performed successfully even the request method does
not match.
Which of the following items in the SentLog interface log is set to be automatically resent?
  • A. Setting
  • B. Resend
  • C. Resend All
  • D. Manual Resend
Which of the following statements are correct about the positioning of the OWS platform? (Multiple
Choice)
  • A. The OWS platform is a metadata-based application development platform on the cloud.
  • B. The OWS platform reduces the IT threshold by fully configuring the development mode and enables service personnel to quickly develop applications.
  • C. The TQL (Top Query Language) implements unified configuration of data query conditions and rule matching conditions on the OWS-Plus platform.
  • D. Metadata definition is separated from data storage to ensure flexibility and performance.
Which of the following tools are supported by the flowchart designer? (Multiple Choice)
  • A. Copy
  • B. Delete
  • C. Align up and down
  • D. Right and left alignment
  • E. Cut
ABCDE
Which of the following files is not exported when exporting an interface package?
  • A. Soap
  • B. Rest
  • C. Oauth2.0
  • D. Keystore
Which basic element of an app is used to store data?
  • A. Page
  • B. Service
  • C. Model
  • D. Rule
Which of the following configurations can be used by OWS to integrate two independent systems?
  • A. App Configuration
  • B. Process Configuration
  • C. Rule configuration
  • D. Webservice Configuration
During service input parameter processing, the input of the parameter A is "China" and this data
needs to be converted to "CN" for data creation, which of the following translators needs to be
configured?
  • A. Combine-message
  • B. Related-model-search
  • C. Simple-data-Mapping
  • D. Attachment-translator
Which of the following structures are contained in the Form Panel container? (Multiple Choice)
  • A. Validations
  • B. Datafields
  • C. Button
  • D. Column
ABC
