Huawei h35-911 practice test
HCS Microwave Hardware Installation (Written) Exam
An El cable has a resistance of 75 ohm or 120 ohm. 75-ohm El cable are the same type with the RJ-45
LAN cable.
Which of the following must be prepared for first-aid?
  • A. Home address
  • B. Emergency telephone number, and emergency rescue address and map
  • C. Office address
Only qualified first aiders can rescue the wounded, avoiding further injuries.
Which of the following is correct in the vehicle speed?
  • A. Never over speed. Adjust driving speed based on the vehicle, road, and other conditions.
  • B. You can over speed when driving luxury cars because these cares have excellent performance.
  • C. You can over speed when there is on vehicles ahead.
There is no need to check the vehicle conditions every time before driving the vehicle.
Which of the following are requirements of operations in dangerous areas?
  • A. Formulate emergency measures and first aid measures for working in dangerous areas.
  • B. Place an warning sign and Isolation barrier.
  • C. Take protective measures for construction personnel in dangerous areas. Use professional tools for safe operations.
Which of the following is correct when dealing with a snake on the site?
  • A. Drive the snake away
  • B. Kill the snake
  • C. Inform related wildlife protection organizations for further actions.
Site environmental risks need to be assessed by all personnel on the day of visiting the site, or be
assessed on the next day.
Which of the following is correct In operations on powered-on equipment and circuits?
  • A. Operations on powered-on equipment and circuits can be performed only by qualified personnel.
  • B. Anyone who wears insulation clothing can perform operations on powered-on equipment and circuits.
  • C. Heavy current and weak current-related operations can be performed by non qualified personnel.
You still can operate an electrical equipment even though you are not qualified.
