Huawei h35-561 practice test
HCIP LTE RNP&RNO V1.0
Which of the following events can be used to trigger inter-frequency switching? (multiple choice)
  • A. A2
  • B. A3
  • C. A4
  • D. A5
B, C, D
How many types of TDD uplink and downlink subframe configurations are there?
  • A. 3
  • B. 5
  • C. 7
  • D. 9
When X2 handover cannot be performed between eNodeBs, S1 handover is performed.
How many configurations are there for R8 TDD special subframe configuration?
  • A. 3
  • B. 5
  • C. 7
  • D. 9
In which of the following messages will the tracking area information be sent to the MME for
consistency check?
  • A. S1AP: E-RAB setup request
  • B. RRC: RRC connection request
  • C. S1AP: Initil context setup request
  • D. S1AP: S1 setup request
In the preparation phase of RF optimization, which of the following options need to be completed?
(multiple choices)
  • A. Determine optimization KPI goals
  • B. Divide the cluster boundary
  • C. Determine the test route
  • D. Prepare tools and information
A, B, C, D
Which of the following bearer connections are between the UE and the S-GW?
  • A. SRB
  • B. E-RAB
  • C. EPS bearer
  • D. DRB
LTE cell search is performed when the mobile phone is turned on and connected to the network,
based on the primary synchronization signal and the secondary synchronization signal.
Which of the following information cannot be carried by PUSCH?
  • A. Transport format
  • B. CQI
  • C. HARQ feedback
  • D. RRC signaling
Which of the following KPI indicators belong to the retention category?
  • A. Paging success rate
  • B. RRC connection establishment success rate
  • C. Drop rate
  • D. Resource block utilization
The default path for saving logfile is C\Program Files\Logfile.
A CCE (control channel element, control channel element) is composed of several REG (resource
element group, resource particle group)?
  • A. 6
  • B. 7
  • C. 8
  • D. 9
Which of the following carries PUSCH scheduling information?
  • A. DCI format 0
  • B. DCI format 1
  • C. DCI format lA
  • D. DCI format 1B
At this stage, which of the following can trigger a handover in the LTE system?
  • A. RSRP
  • B. CQI
  • C. RSRQ
  • D. RSSI
The O-layer service of the M2000 server parses the messages reported by the network elements into
a unified structure, and the performance service stores the data required by the user into the
performance database.
  • A. adaptation
  • B. physical
  • C. application
  • D. IP
