Huawei h35-560 practice test
HCIA-LTE-RNP&RNO V1.0
Page 1 out of 6. Viewing questions 1-15 out of 84
The drive test scenario judges the success of the handover, usually based on the signaling. On the
terminal side, which of the following signaling starts the handover process?
  • A. Measurement Control
  • B. Measurement Report
  • C. Handover Request
  • D. Handover Command
In the process of LTE network optimization, which of the following data sources are used for problem
location analysis? (multiple choice)
  • A. Project Files
  • B. Traffic statistics and alarm data
  • C. useUser complaint record
  • D. Signaling data
  • E. netNetwork test data
BCDE
Before coverage analysis, it is necessary to obtain basic data such as the planning plan, site
distribution, base station configuration, antenna feeder configuration, RS power and service load
characteristics of the optimized target are
a. Then obtain the information of the existing network data, conduct a comparative analysis, and find
out the areas where the coverage problem may exist.
Regarding TA planning, which of the following statements is incorrect?
  • A. LTE of TAPlanning should be consistent with 2G/3G of LAPlan to be consistent
  • B. Currently LTE of TALCan contain at most 16PieceTA
  • C. LTE of TANumber of cells in Should be better than the corresponding2G/3G LASmall number of medium cells
  • D. Each A single-operator cell can belong to multipleTA
Which of the following carrier bandwidths does LTE support? (multiple choice)
  • A. 40M
  • B. 5M
  • C. 15M
  • D. 20M
BCD
The current frequency spectrum of China Mobile's F-band is 1880MHz to 1900MHz.
TD-LTE UE is set to trigger intra-frequency handover by A3 event. In order to reduce the trigger of A3
event, which of the following parameters can be increased? (multiple choice)
  • A. eventA30ffset
  • B. celllnd ivid ua IOffset_s
  • C. celllnd ividualOffset_n
  • D. hysteresis
ABD
When doing PCI planning, what principles need to be met? (multiple choice)
  • A. Avoid cells with overlapping coverage areaspcimold3same
  • B. Of all the districtsPCIAll different
  • C. Cells that meet the reuse degreePCICan be the same
  • D. Need for cells with overlapping coverage areasPCImold3same
AC
Which of the following is the correct description of the following LTE neighboring cell planning?
(Multiple choice)
  • A. Geographically directly relatedNeighboring cells are generally used as neighboring cells
  • B. For dense urban areas and ordinary urban areas, the distance between stations is relatively close (0.3-1.0kilometer),Neighborhood should do more
  • C. becauseforLTEofThe neighboring area does not exist in orderI,CanProblem, and the detection cycle is very short, so you only need to consider not missing neighbors, not wantSort neighboring cells strictly according to signal strength
  • D. ANRThe function can completely replace the initial networkNeighbourhood planning
ABC
In an LTE network, an interface can be configured between eNODEB and MME. Which of the
following is the interface name?
  • A. S1
  • B. S2
  • C. X1
  • D. X2
Which of the following functions is used for inter-cell interference coordination?
  • A. ANR
  • B. ICIC
  • C. BF
  • D. AMR
In single-site verification, within the visible target coverage area of ​​the base station, which of the
following principles should be met for the RSRP compliance rate of the test road?
  • A. The probability that F band meets RSRP> -HOdBm and RS-SINR> -3dB is greater than 98%; D band is greater than 90%
  • B. The probability that F band meets RSRP> -105dBm and RS-SINR> -3dB is greater than 98%; D band is greater than 90%
  • C. The probability that F band meets RSRP> -lOOdBm and RS-SINR> -3dB is greater than 98%; D band is greater than 90% ・
  • D. The probability that F band meets RSRP> -95dBm and RS-SINR > 3dB is greater than 98%; D band is greater than 90%
The single-site verification test only needs to verify whether the cell status is normal in the idle
mode.
Which of the following is not a weak coverage solution?
  • A. adjusteNodeBTransmit power
  • B. Adjust the antenna azimuth and downtilt angle, increase the antenna height, and replace the high- altitude wire, etc.
  • C. Adjust neighbor relations
  • D. Check whether the room sub-system or repeater is working normally, and check whether there is other radio interference
What are the principles that need to be followed when planning LTE neighboring cells? (Multiple
choice)
  • A. Neighborhoods that are directly adjacent to the geographic location are generally regarded as neighboring cells
  • B. For dense urban areas and ordinary urban areas, due to the relatively close distance between stations (0.3-1.0 km), neighbouring areas should do more
  • C. Because there are no sequential I and possible questions in LTE neighboring cells, and the detection period is very short, it is only necessary to consider not missing neighboring cells, and it is not necessary to sort neighboring cells strictly according to signal strength.
  • D. Turn on ANR to completely replace the neighborhood planning of the initial network
ABC
