Huawei h19-376 practice test
HCS Pre sales IP(Security) Exam
Huawei's new USG6306E AI firewall can provide the following interfaces at the same time.
  • A. Gigabit electrical port
  • B. 10GE interface
  • C. Gigabit optical port
  • D. 40GE interface
In the admission test project, if a normal test function test fails, what should I do?
  • A. Directly tell the customer that the product has a bug and the test fails
  • B. Strive for problem resolution time and test it with customers after the problem is resolved
  • C. Consult the mentor, whether the configuration is wrong and the corresponding precautions
  • D. Consult 400, whether the configuration is wrong and corresponding precautions
B, C, D
Common open source network management software includes
  • A. eSight
  • B. Solorwinds
  • C. Orion Network Performance Monitor
  • D. MRTG
  • E. U2000
B, D,
The features supported by CDN are
A NAT SERVER
B. Content distribution
C. Load sharing
D. Content redirection
E. Content exchange
B, C, D, E
Regarding the application identification of Huawei's USG6000 next-generation firewall, what is the
correct statement?
  • A. When the application characteristics change, you need to upgrade the firewall software.
  • B. Ability to identify applications based on statistical features and associated features
  • C. Identify Shuliang more than 6000
  • D. Ability to distinguish between different functions of the application, such as distinguishing uploads and downloads of network disk applications.
B, C, D
What is the triple used to identify the IPSec tunnel?
  • A. Source IP address
  • B. SPI
  • C. Destination IP address
  • D. Security protocol number
B, C,D
correct statement?
B, C, D
Which of the following are the types of rules supported by host check in terminal security?
  • A. Ports and processes
  • B. Firewall software
  • C. Registry
  • D. Operating system
  • E. File
A, B, C, D, E
The mode of SYN Flood source detection in the ANTI-DDOS solution includes
  • A. Basic mode
  • B. Passive mode
  • C. Advanced mode
  • D. Active mode
Which interfaces are included in the NGFW logical interface?
  • A. LOOPBACK
  • B. VLANIF
  • C. NULL
  • D. ETH-TRUNK
  • E. Subinterface
A, B, C, D
