Huawei h19-374 practice test
HCS Pre Sale IVS (Huawei Certified Pre-sales Specialist IVS) Exam
SafeVideo+ features, the functions are
  • A. Camera recordings installed at important points can be redundant as needed
  • B. The recording of important time periods can be redundant on demand
  • C. When part of the physical hard disk is damaged and the Raid group fails, the Raid group video is still readable
  • D. When part of the physical hard disk is damaged and the Raid group fails, the Raid group can still write video
A, B, C, D
Which descriptions of Huawei video surveillance platform VCN3000 are correct on the equipment
parameters?
  • A. Support mixed insertion of SATA and SAS hard disks, hot-swappable hard disks and online replacement of failed hard disks; SAS channel interface performance 6Gbps:
  • B. Image storage adopts block storage to avoid disk fragmentation:
  • C. Supports LUN non-failure technology. When multiple hard disks are damaged, the recording data on the undamaged hard disks in the Raid group can still be read by the system.
  • D. A single device can simultaneously access video streams: ≤256 channels, forwarding: ≤512Mbps, storage: ≤512Mbps, video playback and download: ≤128Mbps.
A, B, C, D
Which of the following protocols or specifications does Huawei video surveillance platform VCN3000
support?
  • A. ONVIF
  • B. SIP
  • C. clairvoyance
  • D. GB-T28181
A, B, C, D
What is the triple cloudization of Huawei's VCN3000 platform?
  • A. Cloud between different devices
  • B. Cloud between different RAID groups inside the device
  • C. Cloud between different hard drives in the same RAID group
  • D. Cloud between different clients
The main selling point of Huawei's video cloud solution is
  • A. Architecture: Application and data decoupling, software and hardware decoupling
  • B. Data: data sharing, platform intensive, business "flowers blooming"
  • C. Business: rapid business launch, agile integration, plug-in deployment
  • D. Trend: The mode of policing has changed from passive to active, and from during and after the event to before the event
Which of the following features does the lightweight cloud solution include?
  • A. Container
  • B. Resource sharing
  • C. Business collaboration
  • D. Direct storage of video and picture streams
Some cases of Huawei Video Cloud: 80+ customers have been served by the Ministry of Public
Security, provincial departments, prefectures and cities. Which ones can be visited ()
  • A. Longgang, Shenzhen
  • B. Qingdao
  • C. Guangzhou
  • D. Xiamen
A, B, C, D
A video cloud in Guangdong realizes cross-domain deployment and precise strikes. Its core values are
reflected in three views, namely ()
  • A. Comprehensive view: application-defined IPC, comprehensive and detailed
  • B. All sharing: the province's linkage, one point initiation, the whole network responds
  • C. Fully automatic: high computing power, multiple algorithms, second-level retrieval of hundreds of billions of images
  • D. Full intelligence: end-to-end artificial intelligence, replacing human eyes with machine vision
The octopus-like distributed intelligent architecture, the core is to achieve four levels of
collaboration, namely ()
  • A. Resource collaboration
  • B. Data collaboration
  • C. Algorithm collaboration
  • D. Task collaboration
A, B, C, D
Which of the following are included in the value of the VCN3010/3020 cloud cluster?
  • A. Ad hoc network: no need to dispatch server, multiple devices spontaneously select master and slave
  • B. No planning: the newly added front-end camera can automatically allocate VCN according to the current load situation
  • C. High reliability: VCN node failure, business automatic switching; fault node repair, automatic business sharing
  • D. N+0 fully symmetrical architecture, saving redundant video hosts and reducing energy consumption
A, B, C, D
