UPS spare parts cannot be configured with Unistar SCT.
Which of the following elements shall be considered when configuring a UPS? (Multiple Choice)
ABCD
The efficiency of the UPS5000-E (25-75 kVA) power module is 96%.
The operating temperature range of the FusionModule800 is -20°C to +45°C, and that for the Fusion
Mod ule500 is 0°C to 40°C.
What UPS configuration method does the Fusion Mod ule800 support? ()
Which of the following models has the widest input voltage range and is applicable to severe power
grids?
Which of the following parallel system does the UPS5000-A support? (Multiple Choice)
By default, how many POUs are configured for one cabinet of the FusionModule2000? ( )
Do the aisles of the FusionModule800 have skylights? ()
The UPS5000-E (25-125 kVA) only supports top cable routing.
SCT configurator does not require permission application, allowing any user to configure at the
specified URL.
The number of batteries can be adjusted in the process of UPS configuration.
The maximum power of the IT cabinets used by the Fusion Mod ule800 is ()
The pipe routing method for the FusionModule800 is ().
The rated loading capacity of a 2+1 parallel system is a maximum of () times the rated loading
capacity of a single UPS.
