Huawei h13-922 practice test
HCIP GaussDB-OLAP V1.0
Last exam update: Nov 08 ,2026
Page 1 out of 11. Viewing questions 1-15 out of 152
What are the technical characteristics of GaussDB 200 database products?
  • A. Low cost
  • B. High performance
  • C. High reliability
  • D. Support massive data
A, B, C, D
Which of the following components does the user service use to access the GaussDB 200 database?
A.DN
B.GTM
C.CM
D.CN
The entire system network of GaussDB 200 is divided into planes?
A.2
B.3
C.4
D.5
GaussDB 200 only supports general-purpose servers based on x86 architecture.
Which of the following is part of the Manager?
  • A. Active and standby OMS nodes
  • B. Multiple Agent Nodes
  • C. DataNode D.CN node
Which of the following is the overall installation process?
  • A. Preparation before installation
  • B. software installation and deployment
  • C. Inspection after installation
  • D. System configuration
A, B, C, D
Which of the following statements about the GaussDB200 database is correct?
  • A. belongs to OLAT type database
  • B. belongs to OLAP type database
  • C. belongs to the MPP schema database
  • D. Database mainly used for online analytical processing
B, C, D
Which of the following is the GaussDB200 database instance type?
A.CN
B.DN
C. WLM
D.GTM
A, B, C, D
The following values can be expressed as Boolean "true"
A.TRUE
B. "t"
C. "true"
D. "y"
A, B, C, D
(Which of the following is not a binary type
A.BLOB
B.RAW
C. BYTEA
D.TEXT
The following most commonly used integer types are
A.TINYINT
B. SMALLINT
C.INTEGER
D.BIGINT
HLL type storage length is fixed
In the query set operation, the intersection is
A.INTERSECT
B.MINUS
C.EXEPT
D. UNION
(Which of the following clauses is dedicated to the condition filtering function in GROUP BY
operation
  • A. WHERE clause
  • B. HAVING clause C.LIMIT clause
  • D. ORDER BY clause
FULL JOIN and CROSS JOIN results are equivalent
