Huawei h13-821 practice test
HCIP-Cloud Service Solutions Architect V1.0
Last exam update: Nov 09 ,2026
Page 1 out of 36. Viewing questions 1-15 out of 526
Which of the following are cloud-native advantages? () [Multiple choice questions]
  • A. Modules are loosely coupled
  • B. Quick deployment
  • C. Hardware virtualization 0%
  • D. Quick Service Recovery
A, B, D
Cloud architecture design is very flexible and does not require mastering UML. () [Multiple choice
questions]
What are the four major applications of cloud native? () [Multiple choice questions]
  • A. DevOps
  • B. Continuous delivery
  • C. Container
  • D. Microservices
A, B, C, D
What are the three major middleware services of Huawei Cloud? () [Multiple choice questions]
  • A. DCS distributed cache service
  • B. DMS Distributed Message Service
  • C. DDM distributed database middleware
Which of the following services does not belong to Huawei Cloud PaaS service? () [Multiple choice
questions]
  • A. Microservice cloud application platform ServiceStage
  • B. ECS
  • C. Cloud Engine CCE
  • D. Cloud Performance Testing Service CPTS
ServiceStage includes the following capabilities in addition? () [Multiple choice questions]
  • A. Cluster and node resource management
  • B. Microservice Application Development Toolbox Microservice Management
  • C. Database management
  • D. Container and virtual machine application deployment and application management
What stage has the application architecture change evolved to? () [Multiple choice questions]
  • A. Monolithic architecture
  • B. SOA architecture
  • C. Microservice architecture
  • D. Fog technology architecture
What level solutions does Huawei Cloud PaaS have? () [Multiple choice questions]
  • A. Applying zero transformation to the cloud. Automatic deployment and operation and maintenance
  • B. Application + cloud middleware. Reduce operation and operation and maintenance costs
  • C. Application containerization. Second-level elastic scaling, higher resource utilization
  • D. Application of microservices. Decoupling of features. Go Live
  • E. Ultimate business innovation. Function-based programming
A, B, C, D, E
What are the benefits of using containers for business? () [Multiple choice questions]
  • A. is isolated by sharing kernel fine-grained resources. (Reducing business costs)
  • B. Increases security for the business
  • C. Defines delivery and deployment specifications for environment-independent standards. (Improve Delivery Efficiency)
  • D. second fast start and stop (suitable for agile scaling scenarios)
  • E. Improve code development quality
A, C, E
Microservices can solve the following problems compared to the traditional monolithic architecture?
  • A. High maintenance cost
  • B. Long lead time
  • C. code quality is poor
  • D. poor scalability
  • E. New student training cycle is long
A, B, D, E
DCS is mainly used for hot data caching to improve data access capability and reduce database
pressure. () [Multiple choice]
  • B. NO
If the enterprise develops or maintains the middleware itself, then the enterprise needs to handle
the software and hardware installation department by itself Deployment, faults and maintenance,
and bug fixes; out-of-the-box if you use cloud middleware services. () [Multiple choice]
Can an application create multiple containers when creating an application? (Multiple choice
questions)
What are the types of clusters currently supported by CCE () [multiple choice questions]
  • A. Virtual machine
  • B. Bare metal
  • C. Windows
  • D. All three are supported
Huawei CSE supports multi-language microservices access and interworking. The supported
languages   include () [multiple choice questions]
A. Java
B. GO
C. net
D. Node. Js
E. PHP
F. Python
A, B, C, D, E,
