Fusioninsight HD Loader ift row data import and export must be processed in the Reduce stage.
Which two modules are responsible for HDFS NameNode active / standby management and
metadata file merge?
In the Fusioninsight system, which component does the Flume data stream need not pass in the
node?
What are the main features of Hadoop HBase
A, B, C, D
In the 196 FusionlnsightHD system, which of the following methods cannot see the results of the
Loader job execution?
Fusionlnsight Manager externally supports REST interface, SNMP interface, SYSLOG interface
When the Flume process is cascaded, which of the following sink types are used to receive the data
sent by the previous hop Flume?
Fusioninsight HD Loader 41, a connector can only be assigned to a job in use
One of the following descriptions about the HDFS federation of the Hadoop distributed file system is
correct? (Multiple choices)
A, C, D
In the .Fusioninsight HD system, which is the LDAP data synchronization method?
