In the Huawei Active-Passive DR Solution, it is a mandatory step to create consistency groups.
What is the sequence for installing CommServe?
1. Start installation.
2. Select installation items.
3. Configure a DR path.
4. Configure an administrator account.
5. Install a database.
6. Select and configure firewalls.
7. Install .NET framework.
Which of the following are Huawei remote DR Solutions? (Multiple Choice)
In the HyperMetro active-active data center solution, data centers A and B are deployed. If the
storage array in data center A fails, which of the following statements are true? (Multiple Choice)
ABCD
Which is the correct formula for calculating the file system backup bandwidth?
Storage-layer data replication supports data replication across heterogeneous storage arrays.
Suppose that a customer has a third-part storage system and wants to set up a Local HA Solution. Is
that feasible to buy the OceanStor 5600 V3 and only HyperMirror license to serve the purpose?
In the HyperMetro active-active data center solution, the quorum server mode delivers higher
reliability than the static priority mode and ensures service continuity in a single point of failure.
Therefore, the quorum server mode is recommended.
How are full backup, cumulative incremental backup, and differential incremental backup sorted
according to their occupation of backup media?
Which are rules for configuring file system backup policies? (Multiple Choice)
ABCD
