About the description of the FusionSphere OpenStack Cinder module, which is correct (Multiple
choice)
ABC
About the customization capabilities that Huawei Data Center Unified Management ManageOne OC
Operation and maintenance center provides, which description is correct? (Multiple choice)
AC
In the FusionCompute, exporting the template to the shared directory fails, which of the following is
recommended to repair the fault? (Multiple choice)
ABC
In Huawei cloud data center solutions, what are the network modes that VPC supports?
ABC
About FusionSphere OpenStack Neutron Network Docking KVM Virtualization Environment
Description, which is right? (Multiple choice)
ABD
Which of the following description on the FusionAccess virtual machine release is wrong?
In Huawei FusionSphere OpenStack, Cinder and Swift components can provide back-end storage, the
following description about the two, which is wrong? (Multiple choice)
In Huawei FusionCloud desktop cloud solution, which of the following description is wrong about the
virtual machine iCache function?
In the scenario of FusionSphere cloud data center, it is recommended to adopt the active/standby
mode to deploy and provide management system reliability. (Multiple Choice)
ACD
In Huawei desktop cloud application virtualization solution, the shared desktop is based on the
Windows Server 2012 R2 version's RDS service to publish applications. Control and manage the
application centrally in the Windows Server. Provide users remote applications service at any time,
anywhere. The end-user does not need to install the application, but still can use the application
program.
