The traffic limiting policy feature only supports the number of connections initiated by the specified
IP or the number of connections received.
Which Of the following IEEE 802.11 standards is also known as Wi-Fi 6?
Which of the following statements about WLAN roaming are true?
What is the correct procedure for a VLAN pool to assign terminals to VLANs.
None
An engineer sets the CAPWAP heartbeat detection interval to 20 of the active link before an
active/standby switchover occurs?
As shown in the following figure, a new AP is deployed In dual link MSB networking (load balancing
mode). Which AC will the connect to?
There are two BFD operating modes. In_______mode, the local end sends BFD Control packets at
specified intervals, and the remote end checks whether the local end periodically sends BFD Control
packets. (Use lowercase letters.)
primary
BFD control packets are encapsulated in UDP packets for transmission. What is the destination port
number of multi-hop BFD control packets?
The Interface \P address and VRRP virtual IP address can be the same.
Drag the following VRRP states to the corresponding working mechanisms.
None
Master
Backup
Master
Backup
