Huawei h12-811 practice test
HCIA-Datacom V1.0
Page 1 out of 21. Viewing questions 1-15 out of 304
VLANs can be assigned based on service types during campus network planning.
When the host accesses the web service of the server, the value of the "Protocol" field at the
network layer is 6.
Which of the following protocols can be used to prevent Layer 2 loops on a campus network?
  • A. SNMP
  • B. RSTP
  • C. NAT
  • D. OSPF
On VRP, the command lines are classified into four levels in increasing priority: Visit level, Monitoring
level, Configuration level, and Management level. At which level, the operator is permitted to
configure service but is not permitted to operate the file system?
  • A. Visit level
  • B. Configuration level
  • C. Monitoring level
  • D. Management level
Which of the following is the full name of VRP?
  • A. Virtual Routing Platform
  • B. Versatile Routing Platform
  • C. Versatile Redundancy Platform
  • D. Versatile Routing Protocol
What are the components of the OSI reference model from top to bottom?
  • A. Application layer, presentation layer, session layer, network layer, transport layer, data link layer, and physical layer
  • B. Application layer, presentation layer, session layer, transport layer, network layer, data link layer, and physical layer
  • C. Application layer, transport layer, network layer, data link layer, and physical layer
  • D. Application layer, session layer, presentation layer, transport layer, network layer, data link layer, and physical layer
On the command line interface of Huawei AR routers, the role of the Save command is to save the
current system time.
On the VRP, when the mkdir test command is run, the system creates a directory named test.
The router ID of the OSPF process takes effect immediately after being changed.
Which of the following IPv4 addresses can be directly used by a host to access the Internet?
  • A. 172.32.1.1/24
  • B. 10.255.255.254/24
  • C. 192.168.1.1/24
  • D. 172.16.255.254/24
In the following figure, after the OSPF routers converge, in which state is the OSPF neighbor
relationship between Router B and Router C?
  • A. Full
  • B. Down
  • C. 2-way
  • D. Attempt
Refer to the graphic, which of the following statements is true about OSPF topology and
configuration?
  • A. Compared with R1, R2 is more likely to become the DR because the DR priority of the interface on R2 is lower than that of R1.
  • B. After the default network type of the interface on R1 is restored to broadcast, a stable OSPF neighbor relationship can be set up between R1 and R2.
  • C. After the default network type of the interface on R1 is restored to broadcast and the hello packet sending interval is changed to 10s, a stable OSPF neighbor relationship can be set up between R1 and R2.
  • D. A stable OSPF neighbor relationship can be set up between R1 and R2.
The router ID of the OSPF-enabled router must be the same as the IP address of an interface on the
router.
With what kind of routers does a DRother router exchange link state information and route
information?
  • A. DRother
  • B. DR
  • C. BDR
  • D. All OSPF neighbors
If the network administrator assigns the IPv4 address 192.168.1.1/28 to a host on the network, how
many hosts can be added to the network where the host resides?
  • A. 13
  • B. 15
  • C. 14
  • D. 12
