Huawei h12-723 practice test
HCIP-Security-CTSS V3.0 Exam
Which of the following behaviors IPS can not detect?
  • A. Virus
  • B. Worm
  • C. Spam
  • D. DOS
URL filtering, according to the classification of the remote or local classification, the user can create
multiple urls strategy, determines the corresponding processing action in URL strategies, a URL
strategy was applied to the domain, which can realize the corresponding URL filtering.
Which of the following description is incorrect against server loophole security threats ?
  • A. worms using application software loophole to spread wantonly, consume network bandwidth and destroy important data.
  • B. hackers, malicious employee use loophole to attack or invade enterprise servers, business secrets were tampered, damaged and theft .
  • C. As long as the system software update in time for system loophole problems can be effectively solved.
  • D. The Internet has made application software loophole to spread rapidly, making loophole easier to become targets of attack.
The greater Virus Scan rating value, the higher the virus detection rate, but the smaller the
probability of false positives.
Which of the following statement is correct about AV engine when Execute the command display av
version?
  • A. version loaded successfully
  • B. did not load
  • C. Loading
  • D. not enough information to determine
IPS custom signature in UTM supports you to set direction and protocol type.
When using the misuse of inspection technology, normal user behavior and invasion characteristics
knowledge base match successfully will be false positives.
Webmail filter support Intranet users receive mail filtering.
Which of the following statement is not correct about application and identification of knowledge
base upgrade?
  • A. When USG device unable to connect to the Internet, you can choose local upgrade
  • B. When the USG devices can connect to the Internet, can upgrade manually and automatically​
  • C. The upgrade process of abnormal will not be able to return to the original Knowledge base
  • D. You can configure the automatic save function, after saving the upgrade application control is configured as system configuration
For security priority application environment, should be closed Huawei firewall UTM overload
protection function.
