Huawei h12-711-v4-0 practice test
HCIA-Security V4.0
Page 1 out of 7. Viewing questions 1-15 out of 91
Match each of the following application layer service protocols with the correct transport layer
protocols and port numbers.
Kalil
3 months, 2 weeks ago
SNMP
HTTPS
FTP
DNS
HTTP
TELNET
Which of the following attack methods is to construct special SQL statements and submit sensitive
information to exploit program vulnerabilities
  • A. Buffer overflow attack
  • B. SQL injection attacks
  • C. Worm attack
  • D. Phishing attacks
A Web server is deployed in an enterprise intranet to provide Web access services to Internet users,
and in order to protect the access security of the server, it should be divided into the _____ area of
the firewall.
  • A. DMZ
  • B. DMY
At what layer does packet filtering technology in the firewall filter packets?
  • A. Transport layer
  • B. Network layer
  • C. Physical layer
  • D. Data link layer
As shown in the figure, the administrator needs to test the network quality of the 20.0.0/24 CIDR
block to the 40.0.0/24 CIDR block on Device B, and the device needs to send large packets for a long
time to test the network connectivity and stability.
  • A. tracert -a 20.0.0.1 -f 500 -q 9600 40.0.0.2
  • B. ping -a 20.0.0.1 -c 500 -s 9600 40.0.0.2
  • C. ping -s 20.0.0.1 -h 500-f 9600 40.0.0.2
  • D. tracert -a 20.0.0.1 -c 500 -w 9600 40.0.0.2
WAF can accurately control and manage users' online behavior and user traffic.
ARP man-in-the-middle attacks are a type of spoofing attack technique.
Please classify the following security defenses into the correct classification.
Regarding the characteristics of the routing table, which of the following items is described correctly
  • A. Port When a packet matches multiple entries in the routing table, it is forwarded based on the route entry with the largest metric.
  • B. Port In the global routing table, there is at most one next hop to the same destination CIDR block.
  • C. There may be multiple next hops in the global routing table to the same destination.
  • D. Port When a packet matches multiple entries in the routing table, it is forwarded according to the longest mask.
When the Layer 2 switch receives a unicast frame and the MAC address table entry of the switch is
empty, the switch discards the unicast frame.
Among the various aspects of the risk assessment of IS027001, which of the following does not
belong to the system design and release process?
  • A. Hold a summary meeting of the project in the information security management stage
  • B. Determine risk disposal measures and implement rectification plans
  • C. Determine risk tolerance and risk appetite
  • D. System integration and information security management system document preparation
Which of the following types of malicious code on your computer includes?
  • A. Oral virus
  • B. Trojan horses
  • C. Port SQL injection
  • D. Oral spyware
A, B, C, D
For which of the following parameters can the packet filtering firewall filter?
  • A. Port packet payload
  • B. IP address of the port source destination
  • C. The MAC address of the source destination
  • D. Port number and protocol number of the port source
What is the security level of the Untrust zone in Huawei firewalls?
  • A. 10
  • B. 20
  • C. 5
  • D. 15
Which layer of the protocol stack does SSL provide end-to-end encrypted transmission services?
  • A. Application layer
  • B. Data link layer
  • C. Network layer
  • D. Transport layer
