Access control system can only set whether the user can open the door, can not be set when to open
the door.
Whare are UPS common working modes? (Multiple choice)
R410a refrigerant in the moment of spray out, can frostbite human skin and deeper muscles in a very
short period of time and cause frostbited dermal necrosis.
What throttle devices does Huawei air-cooled precision air conditioning use? (Multiple choice)
When using PoE (Power over Ethernet) interface, it has two functions: communication and power
supply.
The main monitoring objects of data center room monitoring system are power systems,
environmental systems, fire protection systems etc.
In the main inverter modeT the inverter will change from main inverter to battery inverter mode
when overloaded.
When the sunroof actuator senses a smoke alarmr it can not control the flip sunroof to open
automatically.
Cryogenic components improve the continuous low pressure caused by low temperature start-up,
thus allowing the air conditioner to start up normally.
Gas fire protection systems are fire extinguishing systems that inject gas (including steam, aerosol) as
a fire extinguishing medium.
