163/164
Questions & Answers PDF
P-
On an N+1 backup network, the AP establishes a CAPWAP link with the primary AC. The standby AC
sends the primary discovery packets to the local device. The resource consumption of the AP is
smaller than that of the dual link.
A. Correct
B. False
As shown in the figure, regarding the active/standby mode of the dual-system hot backup solution,
the following statement is wrong?
The following is the correct configuration for referring to the AP system template and the MESH
template?
What is wrong about the description of the business VAP below?
B, C, D
What is wrong about the return type VAP description below?
A. Complete MP neighbor discovery
B. Complete the MESH connection establishment and data return function
C. Establish routing topology between nodes by forwarding route management packets on the
backhaul link
D. Multiple RF backhaul VAPs can be created for each RF
P-
In the meshed MESH networking, the following description of the MESH path is correct?
B, C, D
Taking 5GHz as an example, if the transmitting and receiving antennas are separated by 1km, the
radius of the Fresnel zone is roughly?
Both the N+1 backup and the dual-link cold backup support the link switchback function. To avoid
frequent network switchovers, N+1 backup and dual-link cold backup are waiting for 20 heartbeat
cycles by default. Switch back operation.
The device receives an exception notification when the primary and backup service packets sent by
the peer are not received within the time interval between the primary and secondary service
packets and the number of retransmissions. Prepare to rebuild the primary and backup backup
channels.
A. Correct
B. False
P-
When the VRRP hot backup is configured, the active and standby ACs can be hot standby through
Layer 3 interworking on two different Layer 2 networks.
