HP hpe7-a05 practice test
HPE Network Data Center Professional Exam
Page 1 out of 7. Viewing questions 1-15 out of 100
Which of the following is a commonly used protocol for securely transferring files over a network?
  • A. RDP
  • B. Telnet
  • C. SSH
  • D. FTP
SSH (Secure Shell) is a protocol used for secure file transfer and remote access
What embedded diagnostic tool in Aruba Data Center helps to identify and resolve network security
vulnerabilities?
  • A. Network Insight
  • B. ClearPass
  • C. RFProtect
  • D. Aruba Sensor
ClearPass is an embedded diagnostic tool in Aruba Data Center that helps to identify and resolve
network security vulnerabilities.
Which of the following is a feature of VLANs that allows devices in the same VLAN to communicate
with each other?
  • A. ARP
  • B. DHCP
  • C. Inter-VLAN routing
  • D. Subnetting
Inter-VLAN routing allows devices within the same VLAN to communicate with each other.
When maintaining and optimizing a data center solution, what is a common task that should be
regularly performed to ensure optimal performance?
  • A. Changing the network topology
  • B. Powering off the equipment overnight
  • C. Checking for software updates
  • D. Ignoring performance reports
Regularly checking for software updates is crucial to maintain security and performance in a data
center solution.
What is the purpose of regularly optimizing an Aruba data center solution?
  • A. To enhance security
  • B. To reduce costs
  • C. To increase scalability
  • D. To improve performance
Regular optimization helps to improve the performance of the data center solution, leading to better
efficiency and user experience.
Which tool is commonly used in Aruba Data Center to monitor and diagnose the health of physical
servers and virtual machines?
  • A. Aruba Sensor
  • B. AirWave
  • C. NetEdit
  • D. Aruba Central
Aruba Sensor is a tool commonly used in Aruba Data Center to monitor and diagnose the health of
physical servers and virtual machines.
How can you ensure service level agreements (SLAs) are being met in a monitored data center
environment?
  • A. All of the above
  • B. Setting up SLA monitoring alerts
  • C. Regularly reviewing performance reports
  • D. Conducting periodic SLA audits
Ensuring that SLAs are being met in a monitored data center environment involves activities like
regularly reviewing performance reports, setting up SLA monitoring alerts, and conducting periodic
SLA audits.
What embedded diagnostic tool in Aruba Data Center can help in resolving issues related to VLAN
configurations and network segmentation?
  • A. Aruba Sensor
  • B. ClearPass
  • C. NetEdit
  • D. RFProtect
NetEdit is the embedded diagnostic tool in Aruba Data Center that can help in resolving issues
related to VLAN configurations and network segmentation.
When configuring a server for load balancing, which algorithm is used to distribute traffic based on
server load?
  • A. Least connections
  • B. Source IP
  • C. Weighted Round Robin
  • D. Round-robin
The Least Connections algorithm distributes traffic based on the server with the fewest active
connections.
Which Aruba feature is used to automate the provisioning of network devices during the installation
process?
  • A. Dynamic Segmentation
  • B. Zero Touch Provisioning
  • C. NetEdit
  • D. Network Assurance Engine
Zero Touch Provisioning is used to automate the provisioning of network devices during the
installation process.
What factor should be considered when planning maintenance schedules for an Aruba data center
solution?
  • A. Internal policies
  • B. Peak usage times
  • C. Vendor recommendations
  • D. Available budget
Considering peak usage times ensures that maintenance activities do not disrupt critical operations
in the data center.
Which of the following is used to create virtual private network (VPN) connections between remote
sites?
  • A. LDAP
  • B. DNS
  • C. SMTP
  • D. VPN concentrator
A VPN concentrator is used to facilitate secure VPN connections between remote sites.
Which of the following is a popular protocol used for configuring network devices securely?
  • A. FTP
  • B. Telnet
  • C. HTTP
  • D. HTTPS
HTTPS (Hypertext Transfer Protocol Secure) is a secure protocol commonly used for configuring
network devices.
What is a primary objective when planning the low-level design of a data center solution?
  • A. Improving efficiency
  • B. Increasing downtime
  • C. Expanding server space
  • D. Reducing costs
Improving efficiency is a primary objective when planning the low-level design of a data center
solution to optimize performance and resource utilization.
In the low-level design phase, what is the purpose of creating diagrams or visual representations of
the data center solution layout?
  • A. Entertainment purposes
  • B. Clear documentation
  • C. Aesthetics
  • D. Easy access to snacks
Creating diagrams or visual representations of the data center solution layout serves the purpose of
clear documentation to aid in understanding and communication.
