HP hpe3-u01 practice test
Aruba Certified Network Technician Exam
How many IP assignable addresses are contained in 10.0.128.0/23?
  • A. 4094
  • B. 254
  • C. 510
  • D. 512
What is a characteristic of IPv4 addresses?
  • A. It is 32 bits long
  • B. It is 128 bits long
  • C. 12 hex-digit notation
  • D. Has zero compression rule
How many addresses does the 255.255.252.0 provide?
  • A. 16384
  • B. 32768
  • C. 8192
  • D. 1024
Which OSI model layer is in charge of creating data?
  • A. Physical
  • B. Transport
  • C. Layer 4
  • D. Layer 7
At which section of the Aruba Central WLAN configuration Wizard can you set the Role Based
controls?
  • A. Access
  • B. VLANs
  • C. Security
  • D. General
Which organization is in charge of determining the International Standards?
  • A. Institute of Electrical and Electronics Engineers
  • B. Wi-Fi Alliance
  • C. Federal Communications Commission
  • D. Internet Engineering Task Force
What is considered a Layer 2 component?
  • A. Router
  • B. Switch
  • C. Transceiver
  • D. UTP cable
What is part of the 5 GHz band?
  • A. Channel 12 and 13
  • B. U-NII 5
  • C. Channels 149 to 161
  • D. Channel 14
Which traffic type is used for one-to-one communication?
  • A. Broadcast
  • B. Anycast
  • C. Unicast
  • D. Multicast
https://www.omnisecu.com/tcpip/ipv6/unicast-multicast-anycast-types-of-network-communication-
in-ipv6.php
Which accurately describes the TCP/IP Model? (Select two.)
  • A. It is a set of communication protocols used on TCP-based networks only.
  • B. It specifies how to compress, fragment, encrypt, and analyze data.
  • C. It specifies how to assemble, address, transmit, route, and disassemble a data packet.
  • D. It is a set of communication protocols used on IP-based networks only.
  • E. It is a set of communication protocols used on Ethernet-based networks only.
Which organization provides certifications that ensure interoperability between WLAN vendors?
  • B. Federal Communications Commission
  • C. Wi-Fi Alliance
https://www.wi-fi.org/certification
Which Wi-Fi technology assists with data privacy on open networks?
  • A. Simultaneous Authentications of Equals (5AE)
  • B. Opportunistic Wireless Encryption (OWE)
  • C. Commercial National Security Algorithm (CNSA)
  • D. Wi-Fi Protected Access 2 (WPA2)
Which unit of measurement is recommended for expressing radio frequency power due to its
logarithmic nature?
  • A. lumens
  • B. decibel relative to isotrope (dBi)
  • C. milliwatt (mW)
  • D. decibel relative to milliwatt (dBm)
Decibel (dB)
Decibel is a logarithmic unit of measure used to express the ratio of two values of the same measure.
This unit is not included to the System International of units (SI), but it is widely used in
communication systems and many other technical fields, as it allows to compare two values of any
nature, provided that these values are expressed in the same unit.
Decibel is a decile of the main, larger unit — Bel. Bel is a common logarithm of the ratio of two
energies. But in practice Bel was a far too big value, therefore its tenth part is used – decibel.
The logarithmic method of presentation of numbers often can be very useful, as it allows to replace
multiplication with addition, division with subtraction, raising to power with multiplication, and
extracting a root with the division.
What is measured in dB in the MRFC:
Gain constant
Sound level
Signal/noise ratio
Signal attenuation
https://en.cyclopedia.ifcg.ru/wiki/Radiofrequency_characteristics
What are characteristics of Aruba Central? (Select two.)
  • A. It must be deployed as an on-premises server.
  • B. It manages networking equipment using SNMP.
  • C. It manages networking equipment using HTTPs.
  • D. It can manage third-party networking equipment.
  • E. It is considered cloud-based network management.
DE
What are the key differences between L2 switches and routers? (Select two.)
  • A. Switches build an ARP table, while routers build a port table.
  • B. Switches build a MAC table while routers build a routing table.
  • C. Switches are considered L2 devices, while routers are L4.
  • D. Switches offer a considerably higher port density than routers.
  • E. Routers offer a considerably higher port density than switches.
