HP hpe2-k45 practice test
Using HPE SimpliVity Exam
A customer has some CPU intensive applications running that will be deployed in the virtual
machines. The customer is concerned that these virtual machines may impact the performance of
the other virtual machines.
What should you recommend to avoid this potential problem and still leverage HPE SimpliVity
features for these virtual machines?
  • A. Present HPE SimpliVrty datastores to external ESXi system that will house these CPU intensive virtual machines.
  • B. Add an external ESXi cluster to HPE SimpliVity Federation, and enable Intelligent Workload ptimizer.
  • C. Add an external ESXi system to HPE SimpliVity cluster, and enable DRS functionality for CPU intensive virtual machines.
  • D. Deploy CPU intensive virtual machines on HPE SimpliVity, and configure for them CPU affinity parameter.
A customer plans to deploy HPE SimpliVity 380 Gen10 LFF H and HPE SimpliVity 380 Gen10 SFF H
nodes. What should you recommend tor this setup?
  • A. Put each type of the nodes in a different federation.
  • B. Replace the LFF nodes with all-flash nodes.
  • C. Put all of the nodes in the same cluster.
  • D. Put SFF and LFF nodes in separate clusters.
What is the difference between crash consistent and application consistent cloning methods?
  • A. Application-consistent clones allow the pending 10 operations to finish before committing them to the database.
  • B. Both methods are the same; the only difference is speed of cloning.
  • C. Crash consistent method should be used only for the virtual machines with Fault Tolerance enabled.
  • D. Application consistent method is available only for Linux operating systems.
A user deleted a file from Linux based virtual machine.
Which HPE SimpliVity data protection feature can be leveraged to recover the flie?
  • A. Restoring a virtual machine from the backup
  • B. Moving a virtual machine from DR site to the primary site
  • C. Reverting to the SimpliVity snapshot
  • D. Using file level restore option
What happens if an HPE mniStack Virtual Controller (VC) fails in a multi-node HPE SimpliVrty cluster?
  • A. All VMs on the node restart in a node where the replica resides.
  • B. HPE SimpliVity Intelligent Workload ptimizer restores the VC from backups.
  • C. The IP address of the VC fails over to another HPE SimpliVity node.
  • D. All VMs on the node go on standby mode to avoid data loss.
A customer wants to provide access to the HPE SimpliVity datastores for compute nodes running
CPU-intensive virtual machines. What should you tell the customer?
  • A. It is supported to connect up to 5 compute nodes per SimpliVity node.
  • B. Additional license is required to connect ESXi nodes to SimpliVity datastores.
  • C. Connecting ESXi compute nodes is possible only when VMFS datastores are configured at SimpliVity Federation level
  • D. Compute nodes must reside in the same cluster as HPE SimpliVity nodes.
Refer to exhibit:
You are using Restore Virtual Machine for a given virtual machine. Which result is achieved by thrs
operation?
  • A. Virtual machine boot partition mapped as IS image to another VM
  • B. New snapshot added to existing virtual machine
  • C. New linked-clone created
  • D. New virtual machine created out of this backup
You try to delete an existing datastore, but the operation fails. What is a likely cause of the failure?
  • A. The datastore is marked as read-only.
  • B. The FC connection between the host and array has failed.
  • C. The management network for a host is disconnected.
  • D. This datastore is not added to your scope.
