HP hpe0-v25 practice test
HPE Hybrid Cloud Solutions
Page 1 out of 9. Viewing questions 1-15 out of 131
You need a tool on a SAN Fabric that Will deliver protocol diagnostic, fabric configuration validation
With SPOCK, and assess the
health of physical ports with self-healing and fabric monitoring.
It must perform end-to-end diagnostics while using predefined templates to reduce configuration
errors.
Which diagnostic tool should be used?
  • A. HPE InfoSight
  • B. On-Line Diagnostics
  • C. Off-Line Diagnostics
  • D. Network Orchestrator
According to the HPE website, HPE InfoSight is a cloud-based AI platform that delivers global
visibility and insights into the health, performance, and capacity of your HPE storage and servers.
It
can also provide protocol diagnostics, configuration validation with SPOCK, and assess the health of
physical ports with self-healing and fabric monitoring1
It can also perform end-to-end diagnostics
while using predefined templates to reduce configuration errors1
your customer is using HPE Infosight in their environment containing ProLiant and MSA systems.
which product supports automatic case creation through InfoSight?
  • A. ProLiant DL120 G7
  • B. MSA 2062
  • C. MSA2040
  • D. proLiant DL560 Gen10
According to the HPE website, HPE InfoSight supports automatic case creation for HPE ProLiant
servers that are connected to HPE InfoSight through HPE Integrated Lights-Out (iLO) Amplifier
Pack1
The ProLiant DL560 Gen10 is one of the supported servers that can benefit from this feature1
your customer needs to capture, store, manage, and analyze a dataset that exceeds capacity of
typical database software tools.
What storage technology should you propose to meet their needs?
  • A. Block Storage
  • B. Containers
  • C. Big Data
  • D. File Storage
According to Simplilearn, big data storage is a new technology that allows you to store large amounts
of data that exceed the capacity of typical database software tools1
Big data storage can handle
various types of data, such as structured, unstructured, or semi-structured data, and provide fast and
scalable access to it1
What does an SSD wear Gauge define?
  • A. Remaining lifetime for the SSD drive
  • B. Type of technology used within the SSD drive
  • C. Type of interface used for the SSD drive
  • D. Maximum speed of the SSD drive
According to HPE, SmartSSD Wear Gauge is a feature that provides an estimate of the remaining
useful life of an SSD drive based on its usage patterns1
It can help you monitor the health and
performance of your SSD drives and plan for replacement or upgrade when needed1
Your customer IS interested in me new MSA storage array and asks tor a demo Of the features and
monitoring capabilities.
which tool should you use?
  • A. HPE Storage Management Utility (SMU)
  • B. HPE Data serves Cloud console (DSCC)
  • C. HPE StoreServ Management console (SSMC)
  • D. HPE InfoSight
According to HPE, SMU is a web-based interface that enables you to configure, monitor, and manage
storage devices.
It also provides performance monitoring and reporting for HPE MSA storage arrays1
With SMU, you can demonstrate the features and monitoring capabilities of the new MSA storage
array to your customer.
your customer wants to update the firmware tor multiple HPE proLiant MicroServer Gen10 Plus
servers.
Which tool must be used?
  • A. HPE Composer
  • B. HPE Data Services Cloud console
  • C. HPE ILO 5
  • D. HPE GreenLake central
According to HPE, iLO 5 is a remote management solution that enables you to configure, monitor,
and update your HPE servers seamlessly from anywhere in the world1
It also provides firmware
update capabilities for HPE ProLiant MicroServer Gen10 Plus servers2
. With iLO 5, you can
demonstrate how to update the firmware for multiple servers easily and securely.
Your customer has multiple, remote sales offices with one HPE ProL1ant server deployed per Site to
run local IT services. They want to centralize the monitoring ana lifecycle management of these
servers using a cloud-based offering.
Which tool would demonstrate this functionality?
  • A. HPE CloudPhysics
  • B. HPE GreenLake Compute Ops Management
  • C. HPE GreenLake Data Services Cloud Console
  • D. HPE InoSight
According to HPE, HPE InfoSight is a cloud-based AI platform that delivers global visibility and
It can also
centralize the monitoring and lifecycle management of multiple HPE ProLiant servers deployed in
remote sites using a single dashboard1
. With HPE InfoSight, you can demonstrate how to simplify
and optimize your customer’s IT operations from edge to cloud.
Your customer needs to consolidate data and add additional block-based storage to their man
document management application. They nave five standalone servers with 10Gb networking
Which storage technology should you recommend?
  • A. Network File System
  • B. Storage Area
  • C. Direct Attached
  • D. Network Attached Storage
According to IBM, a SAN is a dedicated network that provides access to consolidated, block-level
data storage1
A SAN allows multiple servers to access shared pools of storage devices, such as disk
arrays or tape libraries1
. A SAN can help your customer consolidate data and add additional block-
based storage to their main document management application.
Match the HPE storage products to their use case.
HPE MSA2062 -> Provides storage for two HPE ProLiant DL380 Gen10 servers in a branch office1
HPE SimpliVity -> Enterprise HCI with integrated compute storage and data protection2
HPE StoreEver LTO 9 Ultruim 45000 External Tape Drive -> Secures backup data with an air-gap
separation3
HPE StoreOnce 3660 -> Provides a disk-based backup functionality with efficient deduplication
your customer has standardized on the AMD platform and asks tor a new I IJ server.
Which server should you recommend?
  • A. DL365
  • B. DL360
  • C. DL385
  • D. DL560
The HPE ProLiant DL365 Gen11 server is a 1U, single-processor server powered by the AMD EPYC™
9004 Series processor with AMD 3D V-Cache™ technology1
It is designed to deliver high
performance, security, and scalability for diverse workloads such as virtualization, cloud computing,
data analytics, and AI/ML1
The HPE ProLiant DL365 Gen11 server supports up to 64 cores, 4 TB of
memory, 12 NVMe drives, and 8 PCIe Gen4 slots1
It also features the HPE iLO 5 controller, HPE
Smart Array controllers, HPE SmartMemory, and HPE Silicon Root of Trust for enhanced
management, security, and reliability1
The HPE ProLiant DL360 Gen11 server is a 1U, dual-processor server powered by the Intel® Xeon®
Scalable processor family2
It is designed to deliver performance, security, and flexibility for diverse
workloads such as virtualization, cloud computing, database, and AI/ML2
Gen11 server supports up to 40 cores, 3.2 TB of memory, 10 NVMe drives, and 6 PCIe Gen4 slots2
It
also features the HPE iLO 5 controller, HPE Smart Array controllers, HPE SmartMemory, and HPE
Silicon Root of Trust for enhanced management, security, and reliability2
The HPE ProLiant DL385 Gen11 server is a 2U, dual-processor server powered by the AMD EPYC™
9004 Series processor with AMD 3D V-Cache™ technology3
data analytics, and AI/ML3
The HPE ProLiant DL385 Gen11 server supports up to 128 cores, 8 TB of
memory, 24 NVMe drives, and 16 PCIe Gen4 slots3
management, security, and reliability3
The HPE ProLiant DL560 Gen11 server is a 2U, four-processor server powered by the Intel® Xeon®
Platinum processor family4
It is designed to deliver performance, security, and scalability for
mission-critical workloads such as database, ERP, CRM, and AI/ML4
server supports up to 112 cores, 12 TB of memory, 12 NVMe drives, and 12 PCIe Gen4 slots4
It also
features the HPE iLO 5 controller, HPE Smart Array controllers, HPE SmartMemory with Persistent
Memory support (up to 6 TB), and HPE Silicon Root of Trust for enhanced management, security, and
reliability4
Therefore, if the customer has standardized on the AMD platform and asks for a new 1U server, the
best option would be the HPE ProLiant DL365 Gen11 server, which offers the highest core count (64),
memory capacity (4 TB), and NVMe drive support (12) among the single-processor servers powered
by AMD EPYC™ processors. The other servers either use Intel processors or have a larger form factor
(2U).
your customer has an existing MSA 2060 with 20 SAS drives. They want to enhance the performance
by adding SSD drives in the four remaining slots
What mandatory option must be sold with the four SSD drives?
  • A. HPE Advanced Data services suite license
  • B. HPE PointNext Advisory & professional services
  • C. HPE MSA Health Check Tool
  • D. HPE Data Services Cloud Console subscription
According to HPE, this license enables advanced features such as performance tiering and RAID tier
affinity for HPE MSA 2060 storage arrays1
These features can help enhance the performance of SSD
drives by automatically moving hot data to faster drives and keeping data on the same RAID group1
You are considering requirements for a database server.
What is the most important component to employ?
  • A. File and Print software
  • B. GPU accelerators
  • C. Antivirus Software
  • D. Fault-tolerant memory
According to Database Design Resource, fault-tolerant memory is a type of memory that can detect
and correct errors without affecting the performance or availability of the database server1
Fault-
tolerant memory can help prevent data corruption and loss, which are critical issues for database
servers1
Map the HPE platform and workload-oriented solutions with the customer’s challenge.
Containers solutions -> Simplify acquisition and deployment of complex systems1
Data Management and Analytics solutions -> Accelerate time to value from insights2
Hybrid Cloud solutions -> Unify operations and management3
Transcoding & Visualization solutions -> Provide stability to scale anywhere
VDI solutions -> Improve user experience while managing costs
you are preparing a proposal to refresh your customers existing OL380 GE and G7 servers With newer
generations. Before making a decision, your customer needs to know if a refresh is worth the cost.
Which option show the value of the purchase to your customer?
  • A. Solution sales Enablement Tool
  • B. selective Storage presentation
  • C. TCO/ROI Calculator
  • D. Smart CID
According to HPE, the TCO/ROI Calculator is a tool that helps you compare the total cost of
ownership (TCO) and return on investment (ROI) of different server solutions1
. It can help you
demonstrate how a server refresh can reduce costs, improve performance, and increase efficiency
for your customer.
your customer wants to purchase a new HPE MSA controller enclosure fully populated With SSD
fives. They have four existing expansion enclosures from their previous solution that they want to
connect to the new controller.
Two expansion enclosures are fully populated with SFF disks, and the other two are populated with
LFF drives.
which storage controller enclosure solution should you recommend?
  • A. HPF MSA 1060 with Advanced Data Service (ADS) suite LTLJ
  • B. HPE MSA 1060
  • C. HPF MSA 2060 with Advanced Data service (ADS) suite LTU
  • D. HPE MSA 2060
HPE MSA 2060 Storage solution supports a mixture of 3.5 inch LFF and 2.5 inch SFF expansion
enclosures for a maximum of 9 enclosures (10 total including the array). This means that it can
accommodate the four existing expansion enclosures from the previous solution that have different
disk sizes.
The HPE MSA 2060 also delivers up to 395,000 IOPS, which is up to 80% faster than its prior
generation1
. This would be beneficial for a customer who wants to fully populate the controller
enclosure with SSD drives, which are faster than HDD drives.
The Advanced Data service (ADS) suite LTU is a license that enables features such as snapshot,
replication, performance tiering, virtual disk groups, and thin provisioning on the HPE MSA 20602
These features can enhance the performance, availability, and efficiency of the storage system.
