HP hpe0-s60 practice test
Delta - HPE Compute Solutions
Page 1 out of 6. Viewing questions 1-15 out of 79
A logical interconnect group can span on multiple HPE Synergy frames for which interconnect type?
  • A. Brocade 32GB Fibre Channel Switch Module for HPE Synergy
  • B. HPE virtual Connect SE 32 Gb FC Module for Synergy
  • C. HPE Virtual Connect SE 100 Gb F32 Module tor Synergy
  • D. HPE Synergy 12 Gb SAS Connection Module
Which HPE Virtual Connect feature allows an administrator to suppress excessive inbound multicast
broadcast and destination lookup failure (OLF) packets?
  • A. Pause flood protection
  • B. Loop protection
  • C. LLDP tagging
  • D. Storm control
Which statement about a new HPE SimpliVity deployment is true?
  • A. New HPE SimpliVity deployments give customer flexible choice of hypervisor
  • B. All new HPE SimpliVity models are based on AMD CPUs
  • C. All new HPE SimpliVity models support deduplication and compression
  • D. New HPE SimpliVity deployments are licensed per node not per physical socket
You configured a vVoI datastore using HPE Storage integration Pack for VMware vCenter.
Which storage object should you check using SSMC to verify whether vVol datastore is configured
property?
  • A. App Volume Set
  • B. Storage Container
  • C. Virtual Volume Set
  • D. virtual Volume
Which statement about login redistribution is true?
  • A. Login redistribution is available only If HPE Primera or HPE Alletra is connected directly to the HPE Synergy frame
  • B. Login redistribution is a licensed feature and the number of licenses required depends on the number of active ports
  • C. Login redistribution is supported only on the HPE Synergy Virtual Connect SE 32Gb FC Modules
  • D. Login redistribution is used for login balancing when they are not distributed evenly over the FC links
Which statement about an HPE Oneview support dump is true?
  • A. Appliance support dump by default contains a logical enclosure support dump
  • B. Support dump is a binary file that can be opened only in a dedicated application
  • C. Support dump can be created if HPE Virtual Connect modules are installed in the frame
  • D. Preview support dump is available only when creating an appliance support dump
Which statement about this logical interconnect group is true?
  • A. The master modules are located in the interconnect bays 2 and 5
  • B. For the given downlink speed, the maximum number of frames is reached
  • C. Both master modules are located in the same HPE S ynergy frame
  • D. To use interconnect bay set 3, all compute nodes must be half-height
An administrator tries to open iLO interlace from HPE OneView Instead of being automatically logged
in a login prompt displays
Where should you start the troubleshooting process?
  • A. At the iLO interface to verify whether the ILO Advanced license is properly applied
  • B. At HPE OneView Interface to verify whether the server is In the maintenance mode
  • C. At the iLO interface to verify whether the SSO certificate is removed from an iLO.
  • D. At HPE OneView Interface to verify whether the iLO processor is disabled
Your customer plans to deploy a VMware ESXi with HPE Synergy platform. They also plan a vSAN
deployment leveraging HPE D3940 Storage Modules and SSD drives
The customer requested the following components:
- HPE Synergy frame with ten HPE Synergy 480 Gen10 Plus compute modules
- Two HPE Virtual Connect SE 100Gb F32 Modules for Synergy
- An appropriate number of vSAN Standard licenses for each compute node
- One HPE O3940 Storage Module with 40 SSDs - All required cables and options
Which statement about this request is true?
  • A. vSphere licenses should be added, as vSAN licenses do not replace vSphere licenses
  • B. vSphere Standard licenses should be replaced with Enterprise Plus licenses to enable vSAN
  • C. One HPE Virtual Connect SE 100Gb F32 Module for Synergy should be replaced with 50GD/S ILM
  • D. 20 SSD drives should be removed from this setup, as D3940 supports only 20 SSD or SAS drives.
Your customer plans to deploy a VMware ESXi with HPE Synergy platform. They plan to use
Distributed Switches and DRS cluster
You are preparing a proposal with the following components:
- two HPE Virtual Connect SE 100Gb F32 Modules for Synergy
- an appropriate number of the vSphere Standard licenses for each compute node
- one HPE D3940 Storage Modules with 40 SSDs - all required cables and options
Which statement about this proposal is true?
  • A. One HPE Virtual Connect SE 100Gb F32 Module for Synergy should be replaced with 50GD/S ILM
  • B. vSphere Standard licenses should be replaced with Enterprise Pius licenses to enable requested features
  • C. 2 additional HPE Synergy 480 Gen10 Plus compute modules can be added to this setup
  • D. 20 SSD drives should be removed from this setup, as D3940 supports only 20 SSD or SAS drive.
Your customer has the following HPE Synergy setup
- 3 HPE Synergy 12000 Frames
- 4 HPE Virtual Connect SE 100 Gb F32 Modules
- 2 HPE Synergy 50 GO Interconnect Link Modules
- 36 HPE Synergy 480 Gen10 Plus compute modules
- 2 HPE Composer 2 modules
Which statement about this setup is true?
  • A. To use all compute nodes, the customer must create at least two logical enclosures
  • B. To manage all frames, the customer must buy two additional HPE Composer 2 modules
  • C. The customer must buy 36 HPE OneView Advanced licenses to manage compute modules
  • D. The customer can add one D3940 storage Module to each of the frames
An HPE Synergy customer needs to prevent a timeout and loss of communication during an external
switch firmware upgrade.
Click the parameter that the customer should configure within an uplink set to meet this
requirement
Which statement about HPE Superdome Flex 280 is true?
  • A. It supports 2 to 8 sockets in 2-socket increments.
  • B. it cannot be managed using HPE OneView.
  • C. It must be equipped with at least 768 GB of memory.
  • D. It can support up to two nPars with an external RMC.
You are troubleshooting an HPE OneView server profile that presents a critical state. The server
profile was configured with a Link Aggregation Group
What should you check to fix the issue?
  • A. if both FiexNICs are configured with the same speed
  • B. If the logical enclosure is built on at least three HPE Synergy frames
  • C. if both FiexNICs are connected to different networks
  • D. if the logical enclosure is configured with redundant master modules
Your customer experienced some problems caused by outdated HPE Superdome Flex firmware.
Which update method should they use to avoid these issues in the future?
  • A. HPE OneView method for I/O firmware update procedure
  • B. RMC CLI to update I/O and HPE Persistent Memory firmware
  • C. HPE OneView IT HPE Persistent Memory firmware must be updated.
  • D. HPE SUM if HPE Persistent Memory firmware must be updated
