extreme networks ew0-300 practice test
Extreme Networks Specialist
Page 1 out of 11. Viewing questions 1-15 out of 160
Extreme Networks “I” chipset switches allow you to run simultaneously the Radius and Tacacs+
features.
In a stable OSPF network, all OSPF routers in the same area must have the same LSDB contents.
The IS-IS Routing Protocol has been developed in ISO to provide routing for pure OSI environments.
Which of the following is the default ESRP priority setting for an Extreme switch?
  • A. 0
  • B. 1
  • C. 254
  • D. 255
A TCP type ACL that uses the permit-established keyword filters out SYN packets in one direction.
By default OSPF hello packets are sent out every:
  • A. 2 seconds.
  • B. 10 seconds.
  • C. 30 seconds.
  • D. 40 seconds.
What is an IGP protocol other than OSPF that uses the Dijkstra’s SPF routing algorithm?
  • A. RIP
  • B. IS-IS
  • C. EIGRP
  • D. All of the above
What does the abbreviation PIM stands for?
  • A. Protocol Implicit Multicast
  • B. Protocol Independent Multicast.
  • C. Port Independent Multicast
  • D. Port Implicit Multicast
IP Version 6 has amongst other differences with IP version 4 also a different address length. What is
the size of an Ipv6 address?
  • A. 16 bits
  • B. 32 bits
  • C. 64 bits
  • D. 128 bits
An Ethernet Automatic Protection Switching (EAPS) domain relies on a control VLAN.
That control VLAN must be tagged with an 802.1Q tag.
Select the statements that apply when you compare and differentiate VRRP and ESRP.
  • A. VRRP does not use the number of active ports as a criteria for Master election.
  • B. VRRP can be enabled on VLAN default.
  • C. VRRP and Spanning Tree can be enabled on the same switch and VLAN
The following MAC address, 00:00:5E:00:01:0A represents:
  • A. The MAC address used for ESRP, instance 01.
  • B. The MAC address used for ESRP, instance 10.
  • C. The MAC address used for VRRP, instance 01.
  • D. The MAC address used for VRRP, instance 10.
The Skew time in VRRP is used to ensure that two back-up routers do not switch to master state at
the same time in case of a failover situation.
Within VRRP the election process of becoming the master switch takes place with the following
precedence:
Step 1: The switch with the virtual router’s IP address becomes the master switch.
Step 2: The switch with the highest VRRP priority becomes the master switch.
Step 3: The switch with the highest IP address becomes the master switch.
When limit-learning is configured on a port and the limit is reached the following traffic still flows to
the port.
  • A. Packets destined for the active Mac addresses
  • B. Broadcast traffic
  • C. EDP traffic
